SOS i need help!!
ok i think this block is tost. i pulled the dizzy out and i was trying to replace that little pick up inside of it and as i was looking down inside the hole it look's like shit is all busted up.
its ok, the more parts that fall of the lighter i get.
Ok, answer this question: When the dizzy was IN, did you crank it over and see if the rotor was turning?
If the rotor isn't turning, you have one of the following problems:
1) Timing chain broken
Or
2) dizzy gear messed up in some fasion
3) Cam gear is messed up somehow
Or
SLOW DOWN!!!!! you went from the ignition module and coil to alternater and voltage regulater.... You can take the alternater and voltage regulator off the car and it has nothing to do with spark to the plugs as long as you have battery with a charge.
On a project/driver fix ONE thing at a time when you learning or you will get overwhelmed as loose interest fast.
1. figure out why you dont have any spark. Duraspark and module is the easiest to work with. If you upgrade to a MSD wire box and 2 wires to the DS distributor and your done. I use to spin my last 30665-6800 all day long with a DS and MSD no problems what so ever. (HEI wont do it)
2.If your having charging problems upgrade to a 3G alt (very easy) and you can do away with external regulator crap. And this can be done w/ alt from junk yard for cheap
Give me a call, cell # in sig. I'm in Riverview
Thats not entirely true about HEI and RPM's. My father inlaw and I built a 500hp 327 Chevy that spun to 7500 using an HEI with MSD internals, a mechanical advance kit and a digital box. So HEI can spin just as good as Duraspark. I only recommended the HEI because for a novice the simplicity to set it up is a no brainer. 1 wire,.. how hard could it be?
Your right,.. with an MSD box,.. they work much better. But your talking what,.. $180 - $200 to set it up?
I agree with the rest. Figure out whats wrong first,.. then sort out a solution.
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
well im going to try and get a pay day advance tomorrow, i need someone else to get this thing going for me. i had our great home owners people come up today and there already getting on my ass after two day of trying to work on my car. plus i admit i think i bit off a little more then i could chew with this car. if everything was set up right it would of been a different story but im stuck and i think im starting to mess things up worse then what i started off with. im only gonna have about 200 bucks to spend though. so if someone wants the cash please come get the car. i need to get back to work on thursday as well.
that and i am starting to have a really hard time getting out of bed. i've been under the weather for a little while now and it's starting to look like i might have to see a doctor now.
Because at the level their playing at,.. usually 800 - 1500+hp motors,.. even HEI has its limitations. But for a motor that usually wont see more then 6000 its just fine. Typically if I was building a big block I would use an HEI.
They do make separate external coil kits for HEI distributors and they generally can handle the RPM's much better then the coil in cap setups.
Hurst
I live in northern Pasco county,. so Apollo bch is a little haul for me,.. else I would be happy to take a look at it for you. Free of charge. What ever is wrong with it can not be too complicated. The car was running,.. you were driving it. So its just a matter of tracing it down.
Hopefully someone close by can come help ya out.
Hurst
