Cams or camshafts i dunno
Originally posted by "Someone"
Originally posted by HondaHunter97GT
mmm wet sexy n02 kit yes pumping from a new 255lph (or a 190lph) pump... Oh hell yes about 750 total..?
yeah--about that much or less----but if you run a wet kit youll want a purge valve too----you only need a 190lph pump for your setup---190lph will support over 400hp easily---
200 points away from a 300
Purge values hmmm.
2004 GT: STOCK
1997 GT: Mods: 180 Degree Thermostat, Flowmaster 2 Chambers, MAC O/R H Pipe, MAC Cold Air Intake w/K&N Filter, 75mm Ported Upper Intake w/ 75mm BBK Throttle Body, Screamin Demon Coils with Livewires
1997 GT: has front end damage still drives FOR SALE
AIM:OmFgStFu
2004 GT: STOCK
AIM:OmFgStFu
Guest
Posts: n/a
Originally posted by stangerang
if i were you id get a 100 shot wet kit---its easy to install and you can run it as your car sits now---(except for fuel pump)---but a pump is only $100
Originally posted by FordMan
Dont forget a better fuel regulator and a set of colder plugs.
about the cams---the shm cams i have heard of people lossing 20+hp from them. i have heard some horor stories about dealing with him as well most guys that do a cam swap for a 98- will put a 99+ cam in that is what steeda is doing with all of there cars. or you can take your current cam and send it out to comp cams and give them your set up and they will do a costum regrind i like that option beacuse they will build it to how you want it i.g. the crazy idle you hear with a cam or for a s/c application. i also heard that jms is doing the same thing but dont know anyone that has had it done through them so i couldnt tell you.
1972 nova ss
89 240 sr20det
2002 chevy 1500 truck
1972 nova ss
89 240 sr20det
Guest
Posts: n/a
heh I learn something everyday I heard aftermarket cams sounds nice. But Im kinda newb in that subject about cams.
2004 GT: STOCK
AIM:OmFgStFu
2004 GT: STOCK
AIM:OmFgStFu
that is why you need better heads and such with a larger cam-----if a cam stays open longer or opens more to let more air in----you have to have a head that will let that extra air in as well------
Originally posted by 1_fast_stang
about the fuel pump if you go to big you will have crazy tuning issues because the computer sends all crazy codes to the pump creating major problems. trust me i can tell you all about that.
this is very true too---alot of people that run big fuel pumps also run a boost a pump so they can turn the pump down while normally driving--and turn it up when you want to race.....
