tps adjustment ?
Old Oct 12, 2008 | 08:21 AM
barry bledsoe's Avatar
The lost pony
Default tps adjustment ?
I know this has been been over but I need to know the procedure to set up base idle and tps adj. I un hook the idle air control valve ,set the idle to 700 to 750 rpm then set the tps voltage to .96 is this close what should it be ?
Old Oct 12, 2008 | 08:24 AM
The lost pony
oh its a 92 lx 5.0 5 speed
Old Oct 12, 2008 | 08:53 AM
Zman's Avatar
I gota Cheby
I know the range is close 96-99 seems to be ok
Only 1/4 mile track I know is Gandy Bridge
Old Oct 12, 2008 | 08:54 AM
Zman's Avatar
I gota Cheby
I was also told if you re adjust the throttle blade screw then you need to adjust the tps again
Old Oct 12, 2008 | 10:11 AM
smokeshow's Avatar
Slower Than Dial-up...
I think that is close... for some reason I was thinking 1.0V is the magic number... but can't remember right now...
Old Oct 12, 2008 | 02:00 PM
The lost pony
that seems to be close it idles real good now but sometimes hunts idle. It had a bad iac valve I think. I took a used one from a 2.3 motor and I had cleaned it real good.
Old Oct 12, 2008 | 07:19 PM
StangItMan's Avatar
This link helped me a bunch!!!
Idle Surge - Joel 5.0
The '87 Coupe to be built and raced in our son's memory.
Cameron Lee Koss - 9.1.1991 - 8.05.2011
I can do great things when not experiencing "Man-A-Pause" StangItMan '08
Old Oct 13, 2008 | 04:44 AM
Na306StAnG's Avatar
Flowmaster nut swinger
Set it as close to .99 as you can get it without hitting 1.0
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Oct 13, 2008 | 05:31 AM
$hawn's Avatar
lives in a glass house
this is because when you turn the set screw it moves the throttle blade which moves the TPS sensor from its static "closed position". this is why you have to readjust the TPS after you move the adjustment screw.
....and in theory the car is supposed th idle off of the IAC not the throttle blade. <----I realize this rarely works on a motor with big heads and cam.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Oct 13, 2008 | 08:38 AM
Joker Instituted's Avatar
wanna be ford guy.
i've been wondering this same thing. but how do you adjust it? i know on some of my other cars i have had you can lossen up the tps and shift it but i cant do that on my mustang. not trying to steal the thread but it's better then starting a new one on the same topic right.
its ok, the more parts that fall of the lighter i get.
