tps adjustment ?
Old Oct 13, 2008 | 09:49 AM
DrDirt's Avatar
Team Geritol Racing
Wobble out the screw holes with a drill to get a little more movement out of it. Actually, any reading you can get between about .94v and .99 v is good because the EEC takes a reading at Key On and uses that value as closed throttle and applies that offset to all it's calculations.
YO! Barry! You LOST!
Old Oct 13, 2008 | 10:55 AM
$hawn's Avatar
lives in a glass house
to add to that...please correct me if I'm wrong but I was told that the ECU sees any thing from like .94-.99 as the same value?
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Oct 13, 2008 | 05:27 PM
DrDirt's Avatar
Team Geritol Racing
Well, yeah, it sees that value as RATCH or the lowest TPS voltage reading since the key was turned on. To enter PT or WOT, the TPS voltage must excede the voltage setting for part throttle + RATCH and min TPS voltage for WOT + RATCH respectively. It also comes into play in calculating accel enrichment.
Old Oct 14, 2008 | 09:06 AM
Joker Instituted's Avatar
wanna be ford guy.
i will never question you guys about anything anymore. cuz i havnt a clue what you mean now. lol
its ok, the more parts that fall of the lighter i get.
Old Oct 14, 2008 | 11:27 AM
DrDirt's Avatar
Team Geritol Racing
Ehhh, me either.
It just means to set the TPS anywhere between .94 and .99 volts and you'll be OK. I usually shoot for .96 volts. If you set it too close to 1.0 and it wanders around too much, like it tends to do, it can possibly mess with your idle if it bounces above 1.0 volts
Old Oct 14, 2008 | 12:15 PM
Na306StAnG's Avatar
Flowmaster nut swinger
No shit.....
Learn something new everyday.
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Oct 14, 2008 | 12:24 PM
  #17 (permalink)
DrDirt's Avatar
Team Geritol Racing
I may have made all that up...remember, it's coming from a guy who can't get his car to start (can't figure out where the spark went) Get your but over herr and fix it!
Old Oct 14, 2008 | 12:40 PM
  #18 (permalink)
smokeshow's Avatar
Slower Than Dial-up...
So, yeah, the 1.0 Volt is the magic number you want to stay under. If you get it to .96 you should be near perfect, with +/- some for any fluctuation.
Old Oct 14, 2008 | 02:31 PM
  #19 (permalink)
Na306StAnG's Avatar
Thats the last thing you want to say.... I have this bad ass blow through carb I'm just dying to put it on something. And like $hawn has said once before "Don't fix it carb it"
Largo fl 33773
MV#72427
Old Oct 14, 2008 | 03:05 PM
  #20 (permalink)
$hawn's Avatar
