running alittle hot?
Old Sep 17, 2008 | 02:16 AM
GNs-r-slow's Avatar
Bondsman
Originally Posted by $hawn
most aftermarket electric fans for foxbody mustangs aren't even as efective as the stock fan.
Ive found this out the hard way. After replacing EVERYTHING, I put the stock fan back on and problem was fixed.
Old Sep 17, 2008 | 02:21 AM
GNs-r-slow's Avatar
Bondsman
Originally Posted by IwinUlose
for starters put a 180 thermostat back in the car. 160 have a tendency to make the car run hotter.
I disagree with this, I have always run 160 thermostats and in traffic car runs around 180-185
Old Sep 17, 2008 | 06:00 AM
IwinUlose's Avatar
is breaking shit
The point is depending on how effiecent the cooling system is will determine how well it will cool. If you have a cooling system that doesnt not get heat soaked and can dissipate the heat fast enough you could run with out a thermostat. I've used 160's also but i also had a BE COOL 3 core aluminum radiator, a Mark VII fan with a HI-flow FMS water pump. i could sit in traffic with the fan on the low speed and it would never go above 180.
Originally Posted by killerMikeD
What kinda pussy needs sprockets to do a wheelie anyways?
Originally Posted by 95coBraSVT
I think I still take the "stupid owner" of the month award here.
RIP Tad.
Old Sep 17, 2008 | 06:06 AM
EG2DelSol's Avatar
i just ordered a ford taurus fan and an oversized 3 core racing radiator. lets hope between those 2 things it stops the problem!! thanks for all your input everyone much appreciated!
FastAsLightning01
Old Sep 17, 2008 | 06:36 AM
95coBraSVT's Avatar
banana republic
The three core alone should take care of the problem. The fan was overkill...But, I guess if you want to run in the AZ desert, you still can.
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Sep 17, 2008 | 07:04 AM
$hawn's Avatar
lives in a glass house
at that point you could have run a 100 degree thermostat and your car would have run 180-185.
I like at least a 180 in an EFI street car. BUT>>
When the motor gets hot, its hot. Once the thermostat is open, its open and only serves the purpose of being a coolant flow RESTRICTER for an inadequate cooling system. If your radiator/fan did their job correctly one wouldn't need to slow down the flow of water through it in order for it to be cooled in the radiator.
Everyone who has dropped mad cash on a high flow pump needs to remember that they only need enough pump to flow the coolant through an open thermostat hole.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
