o2 sensor ?
Old Aug 24, 2008 | 07:07 PM
Joker Instituted's Avatar
wanna be ford guy.
Default o2 sensor ?
which wire is the signal sending wire? i have a 4 wire o2 sensor.
its ok, the more parts that fall of the lighter i get.
Old Aug 24, 2008 | 07:59 PM
shinysideup's Avatar
TR Balla Donor Supreme
Just chuck that thing , its slowing your car down.
Old Aug 24, 2008 | 08:02 PM
wanna be ford guy.
your a butt. im putting in a air-fuel ratio gage
Old Aug 24, 2008 | 08:10 PM
svojohn's Avatar
Half an Engine
Use a DVOM and check the wires. The four Wires are; O2 sensor output, O2 sensor ground, 12 volt heater feed, and heater ground.
Old Aug 24, 2008 | 08:14 PM
wanna be ford guy.
right so what color is the o2 output
Old Aug 24, 2008 | 08:18 PM
svojohn's Avatar
Half an Engine
Maybe this might help you: http://www.ngksparkplugs.com/images/...t_11-16-04.pdf
Old Aug 24, 2008 | 08:24 PM
wanna be ford guy.
perfect thanks so much now i can finish. and hey while i got ya here. anytips on my build?
Old Aug 24, 2008 | 08:27 PM
svojohn's Avatar
Half an Engine
What are you building?
Old Aug 24, 2008 | 08:36 PM
wanna be ford guy.
it's the none turbo 1992 2.3 mustang vert.
cold air intake
19lbs injectors (still working out some bugs)
MSD 4 tower coil pack is on the way.
accel plug wire's
bosch platnum 4 fusion spark plugs.
i have a head thats been ported out. i just need to pick it up.
i found a turbo mani that i have to get from another guy on tr
turbo and intercooler thats coming out of a saab. bolt pattern is the same as the svo.
cat has been removed and replaced with a y pipe to split for duel exhaust. 2in. piping.
and i think thats it so far.
o and yes its 5 speed as well.
Old Aug 24, 2008 | 08:41 PM
wanna be ford guy.
im sure if you go read everything ive put up you can see the fun i have stir'd up. lol
