Cometic users - in here
Old Feb 23, 2008 | 01:21 PM
Adrenalin's Avatar
Project Fobra
Thanks for the reply guys.
I'll be using head studs. So I'm still a little confused on which will hold the best for my first time bolting the heads down.
Click - FQuick
flickr
Old Feb 23, 2008 | 01:33 PM
Lumberjack's Avatar
is made outa laffy taffy
do you just apply the spray to the outside of each side of the gasket or do you try and get it between the layers of metal?
All-American Street Car Performance
6187 126th ave north
Largo Fl 33773
727-667-9346
www.aastreetcars.com
Old Feb 23, 2008 | 02:39 PM
chevy eater's Avatar
i just spray both sides of the gasket
Old Feb 23, 2008 | 04:10 PM
n8secstangg's Avatar
you should never use any sealant on them...the only thing i have had to do is put some of that aluminum radiator stop leak in the radiator to get the coolant passages to seal, 150 passes 0f 30#'s of boost and they were fine
www.racinginnovationsfl.com
www.xsrcylinderheads.com
4.842@156 and 7.53@192 on radials
Old Feb 23, 2008 | 04:23 PM
GNs-r-slow's Avatar
Bondsman
^^^ On GN's they do the same thing, but a different type of stop leak. I guess it was a common problem on certain engines and ac-delco sells some tablets that you put in the radiator.
Old Feb 23, 2008 | 05:32 PM
Adrenalin's Avatar
Project Fobra
Hey Chad, did you have to use stop leak imediately or did you blow the gasket and just used stop leak to reseal it? I'll bolt the heads on tomorrow.
Click - FQuick
flickr
Old Feb 23, 2008 | 06:53 PM
  #17 (permalink)
BigDawg's Avatar
has his prioritys ef'd up
You spray both sides of the MLS gasket, some people pull the rivet from the 3 gaskets, I had to do this as well, I dont know why, but my heads would not sit flush on the block with the rivets. But I sprayed both sides, let them air dry for a minute to tack, and drop them on. Torque down in 3 seperate sequences. Also on the Head Studs, look at going a little tighter than the usual spec, I beleive people are going 110 up top and 105 on the bottom with head studs, with bolts, you have to remain at stock specs. I had to do bolts because my Shaft mounted rockers wouldnt allow for studs. Good Luck
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Old Feb 23, 2008 | 11:05 PM
  #18 (permalink)
Iraq&Roll's Avatar
How does the stop leak work with water cooled turbos?
General Stonewall Jackson has been quoted saying that when the time of war comes,
“My advice is to draw the sword and throw away the scabbard".
Old Feb 24, 2008 | 04:09 AM
  #19 (permalink)
GNs-r-slow's Avatar
Bondsman
Its to initially seal, they will seep water if not
Old Feb 24, 2008 | 04:39 AM
  #20 (permalink)
Scott's Avatar
You can thank me later...
Was told to do the same but did not and I am having no issues. If you do use the stuff flush the radiator quickly afterwards so you do not plug it. And no spray on the gaskets either.
9.31 @ 148.12 ( Drag radials, street driven, low boost, no fancy race car shit....
___________________________________________
TR's Official In House Realtor
PM or E-mail Me If you are Looking To Buy/Sell/Rent A Home.
Special TR Bonus For Using My Services.
