Steeda Subframe Connectors
Old Feb 1, 2008 | 03:36 PM
Newguy07's Avatar
Default Steeda Subframe Connectors
I am installing full length subframe connectos and I am trying to weld the torx plate in. I can't weld the torx plate completly because of the rear control arm is in the way.
How did you guys get around this?
Did you remove the rear control arm?
Thanks a lot.
Old Feb 1, 2008 | 05:07 PM
figment's Avatar
Jonathon
i welded everything up exept that part, then i waited until i changed the control arms and then did it.
SOME PEOPLE ARE ALIVE SIMPLY BECAUSE IT IS ILLEGAL TO KILL THEM
Old Feb 1, 2008 | 07:37 PM
Newguy07's Avatar
I got ya...
Why did you change the control arms out?
Also, if I were to remove the control arm just temporary would I just take off that bolt there with a jack underneath it? Then just slide it down?
Old Feb 1, 2008 | 07:43 PM
MiDiablo's Avatar
Yeah, you just unbolt the control arm & swing it down out of harms way. Definitely support the rearend on a jack/jackstand.
As for changing out the control arms - because the stock ones suck. The aftermarket choices out there are far superior.
Old Feb 2, 2008 | 05:42 AM
Newguy07's Avatar
just unbolt it? What about the compression in the spring? I need to support it with a jack right?
Old Feb 2, 2008 | 09:48 AM
Newguy07's Avatar
WEEEW I got the torx plates on.. About 2 hours of work.. Man it SUCKS welding on my back... I soo wish I had a drive on lift... If I were to do it again I would go drive on lifts.
My welds were affected by my uncomfort also.. =(... Oh well they will hold...
