Through the floor exhaust?
Old Jan 25, 2008 | 03:58 PM
Duceanahalf's Avatar
is doing your girlfriend
Originally Posted by GNs-r-slow
Way to hot for no performance gains
was not done for performance gains, he did it for ground clerance. I believe that the lowest part on the chassis is the collector flanges
Old Jan 25, 2008 | 04:07 PM
shinysideup's Avatar
TR Balla Donor Supreme
Brilliant. Hope that fool has gaterade on tap.
Old Jan 25, 2008 | 04:37 PM
KAILUAZ's Avatar
Infidel
That fool knows what hes doing when it comes to race cars
Old Jan 25, 2008 | 05:18 PM
GNs-r-slow's Avatar
Bondsman
Dont see were that would give him ground clearence, considering that wishbone hangs down 5" below the housing. I think it was done for ricer reasons
Old Jan 25, 2008 | 05:54 PM
08GOGT's Avatar
I know on the S197 GTR concept it was done for clearance as a side exhaust with road racing setup did not have enough clearance. Since my plan for my 08 is a Full Griggs GR40 setup and an NA aluminum 5.4L to road race, I was considering the same setup. I just need to research the fuel cell mounting and how the pipes will run
Old Jan 25, 2008 | 06:48 PM
the rear part of the torque arm is lower yes, however since the low part is attached to the rear axle it cant hit the ground on sompression. also with the Panhard wet up you have a very hard time running eshaust past that.
Darius hangs around Corner-Carvers Forums - Powered by vBulletin you should go over there and tell him that he is a ricer.
Old Jan 25, 2008 | 07:21 PM
  #17 (permalink)
smokeshow's Avatar
Slower Than Dial-up...
Why not end it at the muffler?
Doesn't look like a clearance issue to me...
Old Jan 25, 2008 | 10:25 PM
  #18 (permalink)
GNs-r-slow's Avatar
Bondsman
^^^^ That was my thought. To each his own, why would I go start shit I could careless
Its just not for me
Old Jan 26, 2008 | 10:21 AM
  #19 (permalink)
Shamus O'Toole's Avatar
Redneck Yatchclub member
Why not run a flat exhaust like NASCAR does?? They sit a hell of a lot lower then that Stang does.
Dr.Gas :: NASCAR® Catalog
Looks better to............
Old Jan 26, 2008 | 02:17 PM
  #20 (permalink)
smokeshow's Avatar
Actually running NASCAR style exhaust was the first thoughts I had also.. however, I chose to go the cost effective way..
