Crown vic running like crap...
that would be sweet, too bad im not closer to you!
I changed the plugs and boots and its still not running right. the thermostat gasket is leaking into the front spark plug hole, i have to wonder if the COP got burnt out because of that.. The CEL just came back on so I'll get codes run
Plastic I think?
Offroading Spots near Tampa
Green markers = Pay spots
Blue markers = safe free spots
Red markers = not so safe free spots (possible trespass issues)
how positive are that its pinging? those motors are notorious for shitty belt tensioner chatter and coil pack failures. Ive gone thru countless on my old p71. fast easy way to check them is unplug each individual one while engine is running.
SUCH IS THE RULE OF HONOUR.
Chatter would be putting it lightly though, it sounds like someone threw a wrench in a blender.
Coil replaced on #5 cylinder, car is running a little smoother, but still won't accelerate WOT at all..
I pulled it out and sprayed it with MAF cleaner, which is basic electrical component cleaner
can you see if all the elements are on the maf? those burn out/ break off very easily.
did all the other coil packs check out?
I took it to a shop this morning, and they found it was throwing a cat converter code..
They also suggested I replace all the coils with motorcraft parts
