Crown vic running like crap...
Old Jan 23, 2008 | 01:15 PM
  #21 (permalink)
Scott's Avatar
You can thank me later...
Bad coil pack. My Lincoln LS V8 did the same thing a few times.
It is usually from a valve cover leaking into the area where the spark plug screws into the head and shorts out the pack.
Pull the plug wires and look into the holes. If you see one with oil in it there it is. Shitty thing is you will need to replace the valve cover gasket on that side. Make sure to get the Ford ones and not some cheap ones. It is not a hard job, just a lot of time moving shit out of the way.
9.31 @ 148.12 ( Drag radials, street driven, low boost, no fancy race car shit....
___________________________________________
TR's Official In House Realtor
PM or E-mail Me If you are Looking To Buy/Sell/Rent A Home.
Special TR Bonus For Using My Services.
Old Jan 23, 2008 | 01:26 PM
  #22 (permalink)
Clint's Avatar
keyboard hardass
Not ruling this out, but the motor I have uses the COP coil over plug dealies where there isnt an actual spark plug wire. One of the 8 COPs could still go bad though.. I wish I knew how to tell which one..
Offroading Spots near Tampa
Green markers = Pay spots
Blue markers = safe free spots
Red markers = not so safe free spots (possible trespass issues)
Old Jan 23, 2008 | 02:03 PM
  #23 (permalink)
KAILUAZ's Avatar
Infidel
Originally Posted by Duceanahalf
Kailuaz, you gonna be out a copcarsonline this weekend?
Yep I'll be there on Sunday in the morning. Any others form Vicnet or Marauders gonna be there?
Old Jan 23, 2008 | 02:31 PM
  #24 (permalink)
Duceanahalf's Avatar
is doing your girlfriend
not sure about MM>net, but there is a thread on CVN about it. me tackleberry, wildhawk, starman, and maybe a few new members will be out there. ill bring the 85 out.
Old Jan 23, 2008 | 06:26 PM
  #25 (permalink)
Mars_302's Avatar
Race Photographer
it should have told you when you ran codes. If only you were closer to my shop id bring over the computer scanner and the o2 scanner. The scanner I have at the shop lets me do data stream so I can read stuff as it happens and see if everything is kosher
Old Jan 24, 2008 | 04:14 AM
  #26 (permalink)
Clint's Avatar
keyboard hardass
that would be sweet, too bad im not closer to you!
I changed the plugs and boots and its still not running right. the thermostat gasket is leaking into the front spark plug hole, i have to wonder if the COP got burnt out because of that.. The CEL just came back on so I'll get codes run
Old Jan 24, 2008 | 05:11 AM
  #27 (permalink)
Clint's Avatar
keyboard hardass
Got the codes ran this morning, the only code stored was P0163 (i think)
The code said o2 sensor bank 1 sensor 2
this is the same code the car gave when i bought it
Old Jan 24, 2008 | 07:37 AM
  #28 (permalink)
Mars_302's Avatar
Race Photographer
sensor 2 usually means its the downstream sensor, the one after the cat which is the emissions one
Old Jan 24, 2008 | 07:39 AM
  #29 (permalink)
Clint's Avatar
keyboard hardass
and that shouldn't affect acceleration, right?
Old Jan 24, 2008 | 07:42 AM
  #30 (permalink)
91Notch's Avatar
Is workin on his car
No the rear sensor is there only to let the computer know the cats are working properly.
