Need Help with Fuel Pump Issues on 91 Mustang
Old Dec 5, 2007 | 02:04 PM
PearlFlames91Stang's Avatar
Default Need Help with Fuel Pump Issues on 91 Mustang
I just got my Mustang on the road. Apparently someone was too cheap to find out what the real issue with the car was. When you shut the car off, the fuel pump was still humming, so who ever had the car bypassed the fuel relay and wired it into the headlights. So now you have to turn on the lights before the car will start.
Can anyone give me suggestions on why the pump would have been running after the car was shut off? Would there be a problem with the pump itself, or just the relay needing to be replaced? I would hate to put it in the shop if it is something that I could do myself.
Old Dec 5, 2007 | 05:28 PM
RoadRacer's Avatar
Turn 7 at Sebring
Welcome to TR.
I am moving this to Ford Tech.
Patrick -
Old Dec 5, 2007 | 06:18 PM
91Notch's Avatar
Is workin on his car
Sounds like a faulty ignition switch possible.
Old Dec 8, 2007 | 10:24 AM
OldMan's Avatar
Donut Killer
If the relay is good, swap the brain as another check.
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
Old Dec 8, 2007 | 10:29 AM
Na306StAnG's Avatar
Flowmaster nut swinger
Plus 1, Relay should be under the drivers seat!!!
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Dec 8, 2007 | 02:22 PM
LS1COUPE's Avatar
Destroyer of fords
a test light and wiring diagram will make this and easy fix.
Old Dec 8, 2007 | 04:59 PM
Mars_302's Avatar
Race Photographer
was 91 under the seat? I thought that year was by the fender.A faulty relay or igntion switch is what im going to go with. The only time ive ever had a fuel pump work constantly was when the computer died on me. Course the car wouldnt not run after that.
Was your car an orignal v8 car?
