5.0 rangers.
My ex-gf you proably have sene me with her she was at the show and shine with me I told her that a 5.0 will swap into a ranger no problem and now shes all for itIve seen the kits for like 700 etc how much can I round up an engine for?
my buddy has one actualy he was gonna do the same swap it has been sitting in his folks garage for over a year i will have to ask him if he is willing to part with it since he is selling the truck.
Somebody Set Up Us The Bomb.
my buddy DID do it.. hes on the board under trevor hes also got an ex-FHP coupe hitting 12.8s on slicks and gettign ready for the 351 roller swap now for it.. but the rangers cool.. ran a VERY traction limited 14.5 on 17 GT wheels.. wheel hop in every gear.. he did the whole swap really well too.. used all explorer parts os theres TONS of room under the hood and a good strong rear end.. nice truck
Concrete tires = Simulated horsepower
Autocrossing is great.. now if I could just figure out drag racing...
RIP Tim. i miss you, buddy
The best years for Explorer parts are 97-00. Unless you have a older ranger then the 91 (engine and electrical) and 94 (drive train) Explorer would be the better parts.
If your explorer/ranger? has the 4.0L V6 245ci OHC not SOHC and you are going to stay with the V6 4L throw away the FOTZ-B cam and use the FOTZ-A for everything from ’90 through ’92 explorers. The FOTZ-B is very similar to the FOTZ-A except that the timing was advanced 10° to move the torque curve around in order to make it feel a little better with the manual transmission.
Use the F3TZ-A cam for the ’93-’95 Rangers and Explorers that don’t have EGR; and use the F3TZ-B cam for the ’93-’95 engines that came with EGR and for all of the 4.0L engines from ’96 through 2000.
The V6 4.0L pushrod engines are all conventional 60° Vs with cast iron blocks and heads. The 2.6L block that began with a 3.54½ bore and a 2.63½ stroke ended up with a 3.952½ bore and a 3.307½ stroke by the time it grew into the 4.0L. The block was just about maxed out at this point so the cylinders ended up pretty close together and the rods were crowding the pan rail especially on the 97TM blocks. So thats why i recommend the 97+ v6 blocks.
The A4LD four speed overdrive transmission was introduced in the 1985 Bronco II/Ranger and saw use behind many 4 and 6 cylinder engines until the 1995 model year when it was replaced by the 4R44E and 4R55E electronic transmissions. The A4LD was the first Ford transmission to use an EEC-controlled torque converter lock-up clutch and later became the first to use electronic shift control (via a 3-4 shift solenoid). Adding overdrive to the front of the C-3 three-speed unit created the French-built A4LD. So unlessyou want to go through the whole electrical headache for the 4R44E or 4R55E electronic transmissions i would recommend the A4LD automatic from the 94 explorer/ranger/aerostars because internally most of the thrust washers were replaced with Torrington bearings which made the transmission much stronger and the transmission also got a computer controlled overdrive engagement. At its strongest (off-road race application) these transmissions (A4LD) are holding up to V6s making in excess of 300hp. Once the engines get much higher than that (depends on usage) the main shafts will start bending. Or to avoid all that complexity simply go with the mitsubishi 5spd.
However if you are going to swap to a 5L i wouldnt know i just know about the 4Ls. I would recommend www.4x4central.com for info on V8 5L swaps and kits. I do know the tranny has to go if you switch to the 5L.
Hope this helps you some. Have any questions just PM me.
from what ive read all you need is the special headers and the motor mounts to drop a 5.0 into a ranger then after that is either you carb it or do a EFI conversion setup with harness and computer. I got a 92 shortblock for sale with 61k miles if you need a motor
Someone out there does sell a kit which gives you motor mounts and all the neccessary stuff that would need to be custom fabbed for the swap. I think Craig may know who has this kit since he researched this possibility for his Ranger back in tha day.
Jegs or Summit sell them now
cheap prices I recall acutally
would everyone look at the date this was 1st posted over 9 monthes ago. why are we still responding?
Do not store up for yourselves treasures on earth, where moth and rust destroy, and where thieves break in and steal. But store up for yourselves treasures in heaven, where moth and rust do not destroy, and where thieves do not break in and steal. For where your treasure is, there your heart will be also.
--Matthew 6:19-21
--Matthew 6:19-21
