3-2 brake port conversion
other than emailing the guy from the corral, is there anyone that sells em that I can just order it online from?
kinda wonder if that tee can be bought at parts stores
Steve B, it might help if your post(s) were more informative as to resolving the problem(s) for Mars and I.
Obviously you must know that a line lock is a good route to go - did you use this setup before? If so, how did you plumb it? Details like that would help...
Because as it is right now, I could buy the line lock, and/or the eliminator kit - and instead of having resolution to the situation; I'd have a part, and a problem...
So lend us some of that knowledge already,
A Transbrake allows the transmission to be in forward and reverse at the same time keeping the car still and the drive wheels from turning.
a line lock is to keep a pair of wheels or 4 wheels brakes locked while you let go of the brake pedal.
All line locks i have seen have more than one outlet port on them.
with a 3-2 port conversion, you are allowing both front brakes to run off the same port of a 2 port master cylinder, instead of the back ( maybe front, you have to google that one, i don't remember and it's raining) port and the bottom port.
