Ignition stuck
Old Aug 27, 2007 | 12:48 PM
byondevl's Avatar
Made Of Scars
Default Ignition stuck
K, the starter keeps turning the engine..even after the key is taken out of the ignition. I had to pop the hood and pull off the power wire to stop it. If I put the wire back on the car tries to start.
Old Aug 27, 2007 | 12:55 PM
n8secstangg's Avatar
sound slike teh starter solenoid may be stuck....what year car is it?
chad
www.racinginnovationsfl.com
www.xsrcylinderheads.com
4.842@156 and 7.53@192 on radials
Old Aug 27, 2007 | 12:57 PM
Tiffiny's Avatar
I can fix your bullshit
Couple Of Things Loose Cables/weak Battery Bad Ground Old SOLENOID Bang On The SOLENOID Then Recconnect Battery
Old Aug 27, 2007 | 03:08 PM
byondevl's Avatar
Made Of Scars
chad
84...solenoid is new.....
Old Aug 27, 2007 | 03:27 PM
302andSome's Avatar
bad solenoid man.
I put a brand new solenoid in about a month ago and a week later it did that. Replaced it with another one and it fixed the problem. The best way to tell between the solenoid and the ignition switch is to hook up the battery and when the starter engages remove the single wire on the solenoid post and if it doesn't stop it's your solenoid, if it does stop obviously it's your ignition switch. Just be careful not to burn up your starter in the process.
Old Aug 27, 2007 | 04:03 PM
byondevl's Avatar
Made Of Scars
I smacked it with a socket wrench.....problem solved. wtf
Old Aug 27, 2007 | 04:12 PM
Tiffiny's Avatar
Look At The Ground Real Close Run Another One
Old Aug 27, 2007 | 04:20 PM
byondevl's Avatar
Made Of Scars
from battery or solenoid?
Old Aug 27, 2007 | 04:29 PM
Tiffiny's Avatar
The Cable That Goes From The Batt To Block
Old Aug 27, 2007 | 04:31 PM
Tiffiny's Avatar
Buy A New Terminal End And Cable Connect New Cable To Something Easy Like A/c Compressor Then Reconnect It With Old Cable Via New Terminal Just Guessing Common Prob
