Ford Escort...
Thanks for helping out!
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
SC Motorsports
11801 State Road 52
(727) 856-8768
FordSpeed Racing
Largo, FL 33773
(727) 549-8255
Its I think a 91-92.....So explain how to bleed it with a vaccuum....Also,I dont thing they bled the clutch mas. cyl. before installing it...how do you do that also?....It started to get ALITTLE bit harder,but ended up going back to just the spring pushing it back out.
Thanks guys.
Oh,im begining to thinkg its the throw out bearing,wouldnt that cause the same symptoms?
Rep for all/any help.
Thanks guys.
Fighting for peace is like
screwing for virginity.
TR "Old Skool EF" Member #097
http://www.myspace.com/keith1201
You've probably just got a rediculous amount of air in there. I replace the slave with the master though. They may have replaced the master cylinder for a slave cylinder issue
The throwout bearings usually aren't an issue with these cars.
If you want to use a vacuum pump method. Just push the clutch pedal down and hold while someone cracks open the bleeder screw and vacuums out the fluid. Make SURE you keep fluid in the brake fluid reservoir and don't run out
"Genuine" ASE certified Mazda, Hyundai, Isuzu Technician
Escort Enthusiast Site
Automotive Electrical Specialist, Tuning Specialist
I think you tried to bleed ot by yourself.Go and get atleast a hand pump vacume with catch cup if you cant get help.
