Problem With My 5.0 Engine.....
Old Jul 27, 2007 | 06:05 PM
  #21 (permalink)
Tiffiny's Avatar
I can fix your bullshit
go with the kiss method first
Old Jul 28, 2007 | 05:53 AM
  #22 (permalink)
oreo88's Avatar
"dis shit called deaf"
Originally Posted by Tiffiny
ftw put a thermostat in it and check your oil regularly
i already put a new thermostat on after i heard the pop cuz i thought that may have fixed but....... not really.
it still overheats but not as much thou
Old Jul 28, 2007 | 06:43 AM
  #23 (permalink)
91Notch's Avatar
Is workin on his car
Could have a air pocket in the system somewhere. Is the fan working? How is the condition of the coolant?
Old Jul 28, 2007 | 06:50 AM
  #24 (permalink)
ODB's Avatar
ODB
S.Y.L.O.
be sure to check your ccrm.
Old Jul 28, 2007 | 09:02 AM
  #25 (permalink)
oreo88's Avatar
I turned the car on and the fan doesn't move---- but a friend told me that the fan works when the car gets to normal temp. I thought that was wrong what he told me, buy hey he knew more about cars than me.......could he be wrong???
Old Jul 28, 2007 | 09:03 AM
  #26 (permalink)
oreo88's Avatar
wat's a "ccrm"????? is that the compression test the others are talking about??
Old Jul 28, 2007 | 09:14 AM
  #27 (permalink)
91Notch's Avatar
The ccrm is the constant control relay module. It controls the fans and the a/c clutch. And yes the fan will only turn on if the engine is at a certain temp. You can jump the relay though to make it work with just key on.
