blehhhhh
Yaeh I know what you mean about the struggle to decide looks vs. speed.
You can look at it this way, if your single, you may want looks, if you already have someone then go for speed.
BTW, it looks like your car is pretty tight already give it some juice or do the swap!
These are the engine mods:
densecharger CAI, Pro-M 80mm MAF, Accufab 75mm TB, Trickflow Plenum,
1/2 in plenum spacer, PI intake, PI heads (10.5:1 CR), VT Stage II NA cams,
MAC longtubes, MAC O/R H, Flowmaster American Thunder catback
Only 1/4 mile track I know is Gandy Bridge
what times are you running with these mods?
it went best 12:97 on real street tires with a bad 2.2-3 range 60 footer. so there is a lot left in it if it had some stickys and thats baby shifting. you know "push in the clutch, then move the shifter, then let out the clutch and give it gas
Thats a good time for your car.
03 Cobra, 01 Hayabusa, 06 Scion xB 3.0 #347.
