Thee 26inch vs. 28inch tire debate once again !
Old Apr 13, 2007 | 11:35 AM
Scott's Avatar
You can thank me later...
Question Thee 26inch vs. 28inch tire debate once again !
Since we are lacking in the tech related posts lately I think it is time for one.
I think we all know where I, Adam, and I think $hawn stand on smaller slicks. If not, in a nutshell we like them and seem to have good luck with them. Currently I am running a 275/60/15 MT drag radial which measures 26.25 loaded on the car.
Personally I have stayed away from a 28inch tire for as long as I could because I think they have to much sidewall which tends to make the car sway more easily in the event you have to drive it at all while going down the track. Maybe this is bunk but I have witnessed it several times in person so that is my story on it.
Well I think the time has come where I might have to seriously weigh and re-consider my hatred for 28inch tires since I am about to order some new ones next week.
I plan on ramping up the boost to my car over the next few months and at the rate I am going I am going to go out the back door at the track at 8,000 rpm's. I really do not want to do that and put that extra strain on the motor. Plus the heads on the car will not breath anywhere near that.
So what say you ? Bite the bullet and go with the 28's once and for all or stick with the 26's and see where it all ends up ?
9.31 @ 148.12 ( Drag radials, street driven, low boost, no fancy race car shit....
___________________________________________
TR's Official In House Realtor
PM or E-mail Me If you are Looking To Buy/Sell/Rent A Home.
Special TR Bonus For Using My Services.
Old Apr 13, 2007 | 11:49 AM
Shamus O'Toole's Avatar
Redneck Yatchclub member
Scott, I'm currently running a 26. They work great on the motor, but I'm gonna squeeze it soon so I'm also thinking of makin the switch to a 28.
Old Apr 13, 2007 | 12:13 PM
10sec89's Avatar
You can eliminate alot of the sway if you run the 28's on a wider rim like the outlaw 10.5 guys do. Scaling the cars and making them a lower ride height will help also.
88 LX Hatch,302, E-303, stock long block & Intakes
175 shot,60' 1.42 11.34@116
89 LX coupe, 306, 432 rwhp & 400rwtq 11.004@126. Before blower on all Nitrous 1.48 60' 10.79@122
05 Premium GT, 5 speed, spoiler delete, I.U.P., Dark charcoal leather interior. Stone stock 14.1@101, DeMolet C.A.I. & SCT Xcal2 87 octane tune 13.70@103 w/ 4.10 gears 13.35@105
2003 SVT Cobra. Usual bolt on's 11.61@122
http:/momsracing.com/
Old Apr 13, 2007 | 12:36 PM
fakesnake's Avatar
28x10 0n a 10" rim equalls more foot print and better 60fts.i use more than 8 rim screws to make the tire "round" giving less sway on the big end.im also using goodyear eagles at 9-10 psi. my car leaves and hooks on a 300 shot of nitrous.also running a 4:10 spooled rear.going thru the traps at 72-7300 w/stroked 351w--too high. this season going to change to 3:73 to reduce trap rpm .7000 or a little less would be optimum.
Old Apr 13, 2007 | 01:16 PM
Duceanahalf's Avatar
is doing your girlfriend
even though im at 1/2 the power you are, my 325/50 15 BG drag radials on a 15 x 10" wheel (28" tall) with 15psi sway on the street, but on the track the track perfectly straight.
Last time i was at the track i drove with one hand on the top of the wheel and the other on the shifter the whole time.
Old Apr 13, 2007 | 02:26 PM
$hawn's Avatar
lives in a glass house
sack up and run a 26x8.5 like me
I don't make NEAR the power you do, but they feel nice down track in the mid 10s @ 131+
Adam has been 9.0 on 26x10s
aren't you running a D/R? if so, try a 26x10 on a 10" wheel.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Apr 13, 2007 | 02:56 PM
Scott's Avatar
Sorry, no skinny's on the rear for me ! If they work for you no need to screw with something good. Same reason I am having a hard time convincing myself to change.
Yes I am running a 275/60/15 DR on a 10 inch rim and it measures 26.25 with the car on the ground and a little less than 26.50 jacked up.
Usually I am very decisive but I am having a rough time with this one.
Old Apr 13, 2007 | 03:42 PM
cochese's Avatar
Chucking up the Dueces
you at least have to go 9.08 on the 26's,your student did.
Induction Performance.com
PTC torque converter
Aerospace Components
ProFab Performance
R.I automotive
C.R.T transmisions
5.13@145mph
Old Apr 13, 2007 | 04:10 PM
id let you run mine, but i dont think you can fit a 325 on a 10" wheel with 4" of backspace under your car. that and my rear wheels alone weigh 35#s each + the 30# tire
Old Apr 13, 2007 | 05:09 PM
cochese's Avatar
you can use mine if you want........
ProFab Performance
R.I automotive
C.R.T transmisions
5.13@145mph
