another problem for me...
Old Feb 10, 2007 | 11:47 AM
SkwervE's Avatar
realer than most
ugh i checked them all and they were all fine.. im really hoping it was just a bad connection on the battery..so hopefully this will fix it..i dont understand why it would just happen out of no where..
Old Feb 10, 2007 | 12:14 PM
Mars_302's Avatar
Race Photographer
so like you are driving along and the car just dies and wont start back up? like it wont crank or just wont fire?
Old Feb 10, 2007 | 12:56 PM
SkwervE's Avatar
realer than most
i lose volts while im driving my car and it dies.. and then i cant start it back up..
Old Feb 10, 2007 | 02:38 PM
Na306StAnG's Avatar
Flowmaster nut swinger
Charge your battery and drive the car to advance they can check the alt on the car you may have a wiring problem. The alt may be good but may not work in the car if the wiring is all fucked up fox bodys do that alot.
Edit* Be carefull, I had a 4cyl that caught on fire at the alt plug.
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Feb 10, 2007 | 02:42 PM
Na306StAnG's Avatar
Originally Posted by FordRacing101
ok do the old simple test to check the alt i believe if you have the car running and disconnect the positive battery if the car cuts off then usually that means its your alternator if it stays running then its not and has to be something esle i did this once and it worked for me instead of takin my car to a mech i replaced the alt and no more cut offs good luck man let us know if you figure it out
Dont do that!!!! That can send a voltage spike through your wiring and fry shit.
Largo fl 33773
MV#72427
Old Feb 10, 2007 | 02:52 PM
ODB's Avatar
ODB
S.Y.L.O.
check the ground and other wires in the power distribution box under the hood. There is a ground in that area that can be missed quite easily. This is an 96-98 I believe you had correct? I'll find some pics on the net and pop it up in a couple.
Old Feb 10, 2007 | 03:27 PM
  #17 (permalink)
SkwervE's Avatar
realer than most
yea i checked all the grounds on the distribution box..and everything is ok.. im putting new connector things on the battery cables tommorow morning to see if that fixes it because its really nasty..but i already took the alternator to advance and they said it was fine.. so im out of ideas..
Old Feb 10, 2007 | 03:41 PM
  #18 (permalink)
Jason.'s Avatar
Chris its the atlantic blue ones, mine did the same thing like every other day through 3 alternators and batteries, that color is the fucking devil I tell you, it just looks good on the outside.. , I'll come check her out tomorrow if you want..
2011 Kia Optima SX Premium/Touring package
Old Feb 10, 2007 | 04:58 PM
  #19 (permalink)
Stewart Scott's Avatar
"Now I only have two"
God bless America!
God bless our troops!
God bless the GOP!
Old Feb 10, 2007 | 05:26 PM
  #20 (permalink)
SkwervE's Avatar
realer than most
Originally Posted by Stewart Scott
whats that for?
