Factory ECU for stroker build up
I will be stroking a 351W to a 408. I really want to keep it EFI. Will the A9L be able to work properly with a motor this size? I am sure I will have a nasty cam and some nice heads.
I am just in the planning stages and I am trying to think what would be a nice combo for my coupe. I already have a machined 74 block and have started hording parts for this build.
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Largo fl 33773
MV#72427
I would think that the A9L would get you to the tuner of your choice....
With 42lbs injectors or more, I would want to make sure it has a good A/F!
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
SC Motorsports
11801 State Road 52
(727) 856-8768
FordSpeed Racing
Largo, FL 33773
(727) 549-8255
I ran 42s in the coupe with the matching mass air and had no issues with it. Sam tuned that car with just FP and timing.
SC Motorsports
11801 State Road 52
(727) 856-8768
FordSpeed Racing
Largo, FL 33773
(727) 549-8255
SC Motorsports
11801 State Road 52
(727) 856-8768
FordSpeed Racing
Largo, FL 33773
(727) 549-8255
Stock ECU can support a lot of power. You wont get the full potential though unless it was tuned.
the only thing thats going to limit you is rpm, stock ecu wont go past 6250
Unless you are running an aftermarket block with Cleveland mains, a 408 will not survive long much higher than 6500 rpm. the piston speed on an 408 at that kinds rpm is nearing 200 mph
