Factory ECU for stroker build up
Old Jan 23, 2007 | 11:41 AM
ODB's Avatar
ODB
S.Y.L.O.
Originally Posted by Mars_302
the only thing thats going to limit you is rpm, stock ecu wont go past 6250
chip
Old Jan 23, 2007 | 11:54 AM
$hawn's Avatar
lives in a glass house
Originally Posted by Duceanahalf
Unless you are running an aftermarket block with Cleveland mains, a 408 will not survive long much higher than 6500 rpm. the piston speed on an 408 at that kinds rpm is nearing 200 mph
good point, most aftermarket blocks use cleveland size mains.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Jan 23, 2007 | 12:01 PM
864I'DCaprI's Avatar
doowutchyalike
Nice Pat, A 408 would be sweet .....GL with the build...
(C)lassic (A)merican (P)erformance (R)acing (I)nspired
Old Jan 23, 2007 | 01:17 PM
Duceanahalf's Avatar
is doing your girlfriend
with a 408 W using pistons that weigh 415 g Source at 6500 rpm, 4" stroke and a 6.25" rod
Your Inertia Force is 2,193.65 pounds.
Your Stroke/Rod Ratio is 0.32 .
Effect of Rod/Stroke on TDC and BDC inertia force:
Your Upward Inertia Force at TDC is 2,895.62 pounds.
Your Downward Inertia Force at BDC is 1,491.68 pounds.
at 7000 rpms
Your Inertia Force is 2,544.11 pounds.
Your Upward Inertia Force at TDC is 3,358.23 pounds.
Your Downward Inertia Force at BDC is 1,730.00 pounds.
Those weights are per cylinder Imagine how much stress eight of those are going to put on the block and the entire bottom end.
Old Jan 23, 2007 | 01:33 PM
$hawn's Avatar
at 7000 rpms
better order some good rod bolts, eh
Old Jan 23, 2007 | 02:12 PM
ODB's Avatar
ODB
S.Y.L.O.
every-fucking-thing will be forged. The block is a 74 casting....... I will not scrimp on anything that goes into it.
so should I think twice about the build?? or am I good building all forged?
Old Jan 23, 2007 | 03:39 PM
  #17 (permalink)
ODB's Avatar
ODB
S.Y.L.O.
Originally Posted by bullit proof
A9L will work with no problems. Why are you gonna get a chip? With all that money you got to burn get a stand-alone system. Unless your going to leave it n/a.
example would be?
Old Jan 23, 2007 | 03:45 PM
  #18 (permalink)
Badlatitude's Avatar
bbbblllllaaaaaaahhhhhhhh
Accel DFI
Fast
AEM
Motec
holley makes some shit too
Old Jan 23, 2007 | 04:51 PM
  #19 (permalink)
351coupe's Avatar
refinish artist
Don't back out on it Pat,there have been countless stock 351 block builds thet have made killer power and ran killer times.Like you said,don't go cheap on parts and don't turn a shit load of rpm and it will live a happy long life.
Visit my TR Shop Forum
RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
Old Jan 23, 2007 | 04:58 PM
  #20 (permalink)
ODB's Avatar
ODB
S.Y.L.O.
no...I'm not stopping. But I like all the input from everybody......I just picked up an edelbrock upper and lower for it........it's big!
