Engine talking longer and longer to start
Old Nov 29, 2006 | 09:41 AM
Whaazup17's Avatar
Default Engine talking longer and longer to start
Ok.. when I first got my car 1987 5.0 fox in january... It started up right when I turned the key.. Now after driving it for a while it takes about 4-5 seconds of cranking to start the motor
What is causing this?
Old Nov 29, 2006 | 11:54 AM
BLUE2KSS's Avatar
Mechanical Engineer
starter solenoid could be on the way out, swap it out, its a cheap part and good insurance for later on.
see if that changes anything
Old Nov 29, 2006 | 12:45 PM
Whaazup17's Avatar
ohh? well it isn't like the starter sounds bad.. the starter seems like it cranks pretty strong.. just it takes a while to start... Sometimes it does it sometimes it doesn't...
Old Nov 29, 2006 | 12:53 PM
$hawn's Avatar
lives in a glass house
cycle the key a few times before trying to turn the engine over, see if that helps.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Nov 29, 2006 | 01:06 PM
Whaazup17's Avatar
sorry, what do you mean by cycle the key?
Old Nov 29, 2006 | 01:15 PM
$hawn's Avatar
turn it on then off...a couple of times with out going all the way to start.
Old Nov 29, 2006 | 01:25 PM
Whaazup17's Avatar
ohh ok I will try that.... What should I be checking for? What just after I do that just try and start the engine?
If it starts up right away what could that mean?
Old Nov 29, 2006 | 01:27 PM
$hawn's Avatar
it just primes the fuel system.
Whaazup17's Avatar
ahhh ok.. got ya... thinking it a fuel problem.. Ok let me check that...
Old Nov 29, 2006 | 05:06 PM
riverviewnative's Avatar
Just had on in the shop doing that and it was leaking injectors. Try holding your foot to the floor and see if that helps. If it does try some injector cleaner
