NPT to AN conversion
alright, im plumbing my fuel system and im doing one last rundown before i put it all in... i have 3/8 to -8 fittings for my pump and for my carb feed, for the life of me i want to say these are bottle necks because i thought the -8 was supposed to be 1/2"...but the fittings im lookin at, the 3/8 side looks larger? does someone know where i can get a chart or something with a run down of the npt and AN sizes?
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
take you AN number over 16 and thats your size in inches. -4 is 1/4" -6 is 3/8", -8 is 1/2", a-10 is 5/8", -12 is 3/4"
Are you sure you have -8 fittings? Ill go look and see if i happen to have one here.
The -8 side should be at least the same size as the 3/8, it depends on what brand the fittings are though.
yea, they are still packaged, says 3/8 to -8AN...when i say the sizes look off, the inside diameter looks off. the bore on the 3/8 npt side is physically larger then the bore on the -8AN side.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Maybe compare it to a known -8, maybe a -6 was accidently packaged as a -8
all the AN sides fit on all of the fittings...and the "3/8" threads into my pump and filter...and they are advertised as 3/8 in/out
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
