Piston to Valve clearance
Old Sep 20, 2006 | 02:49 PM
Na306StAnG's Avatar
Flowmaster nut swinger
Originally Posted by boostedOne
I have an explorer shortblock with an E303, 1.7 rockers, stock GT40P heads.
Checked piston to valve last night, and at the tightest point I had .075ish clearance(heads still on, so used checking springs and plunged the valves every few degrees).
I have the Crane spring kit which should be about 110 on the seat and 375lbs at full lift. I dont plan on revving the engine past mid 5s anyhow, since its in my truck.
Think the P to V is adequate?
Thanks.
I'd run it! but it is a little tight.
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Sep 20, 2006 | 03:26 PM
dragula's Avatar
Motherfuckin Trend Killer
Fine for those rpms.
Worst case go to a thicker gasket.
Thats right fools, 2 Prostockers this year
Old Sep 20, 2006 | 06:51 PM
Na306StAnG's Avatar
Trade someone your 1.7 for 1.6. Then you'll be fine!!!
Largo fl 33773
MV#72427
Old Sep 20, 2006 | 06:58 PM
Na306StAnG's Avatar
I guess cross your fingers
Largo fl 33773
MV#72427
Old Sep 21, 2006 | 06:03 PM
harold harper's Avatar
h9
i'm running e cam,1.7 and e7 heads on a stock piston. my heads have 0.020 shaved off them.no problems with them.do 498. dived by 1.6 than times that number by 1.7 and there is your lift number,should be 532. lift
