Where the hell's the fuel pump realay
Old Sep 5, 2006 | 12:24 PM
harold harper's Avatar
h9
look for these color wires on the fuel pump relay two pink wires with a black stripe,tan with light green stripe and a orange withlight blue stripe.mybe this will help you locate your relay.87 to 90 cars i now for sure are under the drivers seat.you my also want to check the saftey switch in the back that kills the fuel pump in a fender bender.if you need to any thing eles let me know, i have the wire scymatic for fox bodys
Old Sep 5, 2006 | 01:29 PM
Pshull727's Avatar
try the one by the ecm the also has to do with the fuel pump
2008 Acura TL DD
1998 Beater Ranger DD
1994 Ford Mustang Project
Old Sep 5, 2006 | 02:03 PM
power2weight's Avatar
-eats the last cookie.
FWIW, apparantly none of the 4-cyl turbo computers I've run supply enough voltage to turn on a regular autoparts store 30-amp relay, it just won't prime the pump.
I'd replace it straight with whatever oem relay ford used, can't get it to work otherwise.
"They must really feed each other to the lions down there........"
Old Sep 5, 2006 | 02:25 PM
DrDirt's Avatar
Team Geritol Racing
Yeah, I know all about the normal stuff for at least the '91 and earlier 5.0's but this '93 2.3 liter thing is a different kind of animal. Did a search on corral but can't find anything specific on what the multifuunction box actually does...but that's gotta be it. I don't know if it's dead or not but I unpluged the fuel pump at the tank and jumped it directly to the battery and it ran just fine. Then I did a daisy chain with what wires and clips I had to the other side of the plug so I could see my test light and turn the key at the same time and got nada on the light. Can't be sure if I had good contact though. I'll try again tomorrow when somebody is here at work with me and see if there is current there. If not, then either the wire is shorted somewhere or themystery box may be dead.
Thanks for the offer $hawn but there are at least 3 of them down at the junk yard so it'll be cheaper there than to buy gas to your place...and I'm a cheap bastige.
YO! Barry! You LOST!
Old Sep 5, 2006 | 02:53 PM
Pshull727's Avatar
hey tony is the engine and ecm wiring harness from a 93 if its not then that will be whats wrong the 93 is a one yr only car you need 93 wiring to make it work it sucks and if you got the wrong harness then the fuel pump will not turn on at all.
2008 Acura TL DD
Old Sep 5, 2006 | 05:54 PM
  #17 (permalink)
$hawn's Avatar
lives in a glass house
Originally Posted by Just Dave
Its the IRCM. I forgot what it stands for, but basically it condenses all of the relays into one fragile, expensive, no longer available new module.
Search for IRCM on Corral or turboford.net
integrated relay control module...
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Sep 5, 2006 | 05:57 PM
  #18 (permalink)
$hawn's Avatar
If that's his only problem, he can wire one in the circuit himself in like ten minutes and solve all his problems.
Old Sep 5, 2006 | 06:09 PM
  #19 (permalink)
460 TZILLA's Avatar
THROTTLE STEER
Default check this out
happened to a friend last week,fuel pump won't turn on if there is no water in the radiator only in the 4 banger 92-93 I swear its true!! I didn't believe it either ...something to due with that multi relay DR.DIRT don't know if you were trying to start this with or without the radiator or water in radiator..
Old Sep 5, 2006 | 06:57 PM
  #20 (permalink)
DrDirt's Avatar
Team Geritol Racing
Nope, it's all '93 stuff, Paul. And the rad is full, Donnie. Looks like it's the Idiotic Relay Crap Mechanism that is the problem. Cool, this will give me the opportunity to add the specia DrDirt customizing touch to the car. Anybody got a paper clip and some Dentyne?
