Where to get?
Old Aug 24, 2006 | 03:47 PM
plazma's Avatar
Default Where to get?
I need to have my sn-95 spindles modified to accept a larger ball joint.
Does anyone know of anywhere that has a ball joint reamer or where I can pick one up locally?
I can't just use a different ball joint or I would so reaming is what its getting!
All this crap about balls and reaming makes this sound like a gaggot thread.
https://www.tamparacing.com/forums/signaturepics/sigpic17840_1.gif
My Project
Old Aug 24, 2006 | 07:17 PM
shinysideup's Avatar
TR Balla Donor Supreme
where to get a good reaming?? Gaggot please!
Old Aug 24, 2006 | 09:31 PM
JDL1000's Avatar
Are you using the spindles on a fox? If you are you don't need to modify anything. Just press the sn95 ball joints out and press in the fox ball joints.
Life moves pretty fast. If you don't stop and look around once in awhile, you could miss it.
-- Ferris Bueller --
Old Aug 24, 2006 | 10:54 PM
plazma's Avatar
The svo ball joints are non serviceable. So pressing them out isnt an option.
Using a fox lca messes with the length as it's only like 13. The sn95 is 13.75 which is still shorter then the svo.
My Project
Old Aug 26, 2006 | 09:51 AM
plazma's Avatar
All you have to do is take the 94-95 spindle and enlarge the hole in it that accepts the ball joint. The svo is larger in diameter just don't want to use a drill bit. The ream is made just for this job. Usally for when a ball joint has to be switched to the larger size.
My Project
Old Aug 28, 2006 | 12:32 PM
plazma's Avatar
I do belevie its tapered. There doesn't seem to be anyone around with a reamer.
I found some online for like 100 bucks.
My Project
Old Aug 28, 2006 | 06:08 PM
Pshull727's Avatar
i think the turbo coupe lca's may work on your car try looking in to that
2008 Acura TL DD
1998 Beater Ranger DD
1994 Ford Mustang Project
Old Aug 28, 2006 | 06:21 PM
Duceanahalf's Avatar
is doing your girlfriend
any 87-88 thunderbird arm should work. the control arms are functionally identical to SN-95 arms.
