Help me find this part!!!!
I want to wire my Fan and Fuel pump to come on when my oil pressure hits 5 or so psi. I knew theres a way to do it. I've had many cars that have been like that but the guys at A&E/summit Don't have a clue
. They found one from NOS but its 39.99. I think you can get it at Autozone just need to know what car and year. Major thanks in advance
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Largo fl 33773
MV#72427
-Ronald Reagan
-Ronald Reagan
Sounds like a Hobbs switch to a relay.
"Congressmen who willfuly take actions during wartime that damage morale and undermine the military are saboteurs and should be arrested, exiled or hanged".
President Abraham Lincoln
Guest
Posts: n/a
Go to NAPA and ask them for the Echlin book, and look for oil pressure switches (they should be OPXXXX part numbers). Look through the description and you'll see the thread size, psi rating for the switch and also whether they are normally open or closed. You want a normally open. This means that with no outside action, the circuit is open. If pressure is reached, it closes the circuit and turns your pump and fan on.
Guest
Posts: n/a
Sure it does. Basically instead of hot wiring his pump and fan to a key-on source, he wants them to be on when the engine is running.
The only problem I could see is if the car sits and oil pressure drops, the fuel pump won't turn on to prime the system until it builds some oil pressure. It may take several seconds for the switch to see the pressure, turn the pump on, prime the system and fill the float bowls.
You are correct. But you'll still need the key and power source and a relay to run those High current devices. I can see running a switch like that on the f/p to turn it off under a set oil pressure. It just sounds like there is no use for the safety switch it that application.
I'm not to sure whats so hard to grasp here. let me try this again.... Running a key on wire from somewhere in the car to the oil pressure switch (thats what i'm looking for) on this "switch" theres going to be to prongs one for the key on. then i'm going to run 2 wires one to each relay (one for the fuel pump one for the fan) this way when the keys on nothings working. until the car build 5 psi of pressure.
Largo fl 33773
MV#72427
Largo fl 33773
MV#72427
