Help me find this part!!!!
Old Aug 4, 2006 | 09:28 AM
Na306StAnG's Avatar
Flowmaster nut swinger
Originally Posted by Just Dave
Sure it does. Basically instead of hot wiring his pump and fan to a key-on source, he wants them to be on when the engine is running.
The only problem I could see is if the car sits and oil pressure drops, the fuel pump won't turn on to prime the system until it builds some oil pressure. It may take several seconds for the switch to see the pressure, turn the pump on, prime the system and fill the float bowls.
Thanks Dave
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Aug 4, 2006 | 09:32 AM
$hawn's Avatar
lives in a glass house
Originally Posted by Na306StAnG
I'm not to sure whats so hard to grasp here. let me try this again.... Running a key on wire from somewhere in the car to the oil pressure switch (thats what i'm looking for) on this "switch" theres going to be to prongs one for the key on. then i'm going to run 2 wires one to each relay (one for the fuel pump one for the fan) this way when the keys on nothings working. until the car build 5 psi of pressure.
wouldn't it be easier to just remember to turn the key off
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Na306StAnG's Avatar
Originally Posted by $hawn
It just sounds like there is no use for the safety switch it that application.
Its got nothing to do with safety just sick of switches to turn shit on and off. And hate turning the key on to hear the pump and fan come on when I just want the radio on. Its just a preference thing for me.
Largo fl 33773
MV#72427
Old Aug 4, 2006 | 09:35 AM
Na306StAnG's Avatar
Not if I want the radio on.
Largo fl 33773
MV#72427
Steve B's Avatar
brings his heater.
Its go nothing to do with safety just sick of switches to turn shit on and off. And hate turning the key on to hear the pump and fan come on when I just want the radio on. Its just a preference thing for me.
hence why i bought a painless box.
Old Aug 4, 2006 | 09:36 AM
Na306StAnG's Avatar
Yea i was thinking about that last night when i was trying to figure out how to do this!!!
Largo fl 33773
MV#72427
Old Aug 4, 2006 | 09:39 AM
  #17 (permalink)
Na306StAnG's Avatar
Go to NAPA and ask them for the Echlin book, and look for oil pressure switches (they should be OPXXXX part numbers). Look through the description and you'll see the thread size, psi rating for the switch and also whether they are normally open or closed. You want a normally open. This means that with no outside action, the circuit is open. If pressure is reached, it closes the circuit and turns your pump and fan on.
I'm going to try that in the moring thanks again dave!!!
Largo fl 33773
MV#72427
Old Aug 4, 2006 | 09:41 AM
  #18 (permalink)
$hawn's Avatar
that's why the ignition switch lets you select accessory or on/run
I'm with Dave....Napa should be able the switch you need.
Old Aug 4, 2006 | 09:43 AM
  #19 (permalink)
Na306StAnG's Avatar
that's why the ignition switch lets you select accessory.
Largo fl 33773
MV#72427
Old Aug 5, 2006 | 07:57 AM
  #20 (permalink)
Na306StAnG's Avatar
Thanks Dave I was in napa for a total of 3 mins. The longest part was them finding the Echlin book.
OP6118 was the part number.
Your the man.
Largo fl 33773
MV#72427
