A minor issue
Old Jul 14, 2006 | 10:37 AM
$hawn's Avatar
lives in a glass house
Originally Posted by CD420
yeah.pulley chatters when cold.not hot......might cause belt slippage. Definately check the water neck on manifold....
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Jul 14, 2006 | 10:38 AM
jabtay's Avatar
Wheres the damn detonator
Originally Posted by $hawn
you know about his car too???
damned hippies put their nose in everyones buisness
"The only thing necessary for the triumph of evil is for good men to do nothing."
"Si vis pacem, para bellum"
Old Jul 14, 2006 | 02:10 PM
OldMan's Avatar
Donut Killer
Yea... he amazes me when he says anything coherent and to rattle that off....
No offense CD!
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
Old Jul 15, 2006 | 04:08 AM
Stewart Scott's Avatar
"Now I only have two"
I just read the part about me having a problem with the water inlet adapter. I thought it was my thermostat housing itself, changed the gasket twice then found that it was the threaded nipple that the bypass hose hooks to and at high RPM's would leak from there. JB welded it and haven't had any problems since. You have to seal the big threaded plug at the top as well. what a shit design but it looks good!
God bless America!
God bless our troops!
God bless the GOP!
Old Jul 16, 2006 | 12:49 AM
jabtay's Avatar
Well I have most of the issues worked out...the exhaust leak is coming from where the dipstick is mounted to the header bolt. It came loose causing the dipstick to rattle, and the exhaust leak. Everything else seems to be doing good again. The temp is back to normal and the alt is charging like usual.
Stewart, Ill take a look at that piece tomorrow, the coolant has to be going somewhere....hopefully its not going the same place it went in my F150
Old Jul 18, 2006 | 03:15 PM
good luck, you will see a pool of water/coolant directly below the bypass hose down in the valley of the timing cover on the left. it would never leak at idle only when I would get it up in RPM's. drove me nuts....also check/change the hose that attaches to the bypass nipple, could just be leaking from there. Hopefully you get it worked out, it is the little things that bother the most.
God bless America!
God bless the GOP!
