Vortec Oil return line
Old Jun 12, 2006 | 05:48 PM
o1yellowGT's Avatar
2wheels > 4 wheels
Default Vortec Oil return line
Has anyone here used the dss oil pan tap they are selling ? I am getting ready to install the sc on my car and am very Leary @ this part of it.DSS sell this but I was wondering where on a 4.6 oil pan you would put it.The front is too shallow ?
Thanks
Sean
DSS Universal Bolt-On Power-Adder Oil-Return Fitting.
Eliminate all the hassles of modifying your pan for a return line. Introducing the NEW!! DSS Universal Bolt-On Power-Adder Oil-Return Fitting. Simple to use and easy to install. It eliminates the tapping of sheet metal and no welding is required. Designed to fit most stock and aftermarket oil pans.
Suggested Retail $49.99
Introductory Sale Price
$29.95
Old Jun 12, 2006 | 05:52 PM
evocrazy1's Avatar
i did it to my 351
ASKED TO BE BANNED
Old Jun 12, 2006 | 06:18 PM
Zman's Avatar
I gota Cheby
wow just what I was looking for my turbo drain. Is there a website for them? thanks Andel
Only 1/4 mile track I know is Gandy Bridge
Old Jun 12, 2006 | 06:39 PM
o1yellowGT's Avatar
2wheels > 4 wheels
www.dssracing.com
Old Jun 12, 2006 | 07:54 PM
riverviewnative's Avatar
That looks alot like the part that holds the railing on our boat. It is aluminum and has the four holes with a 3/8 npt thread.
Old Jun 12, 2006 | 11:30 PM
BigDawg's Avatar
has his prioritys ef'd up
I have that bung, and it works fine, you drill your pan, big deal, I had the advantage of buying a new pan, so with it off I drilled it out and used the fitting.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Old Jun 13, 2006 | 05:23 AM
Zman's Avatar
I gota Cheby
Found the site thanks, just looks easy to do, I don't want to pull my pan as its already setup in my car.
Old Jun 13, 2006 | 05:30 AM
freakyfast95GTS's Avatar
Ghillied up and ready.
plan on using drain already in my pan,Canton is nice enough to put one on the drivers side for me.(using Canton Roadrace pan) will take pics if anyone needs them, its their top of the line roadrace pan with the diamond baffle and windage tray/Crank scraper
" When you men get home and face an anti-war protester, look him in the eye and shake his hand.
Then, wink at his girlfriend because she knows she's dating a pussy." General Tommy Franks
"Congressmen who willfuly take actions during wartime that damage morale and undermine the military are saboteurs and should be arrested, exiled or hanged".
President Abraham Lincoln
Old Jun 13, 2006 | 10:58 AM
o1yellowGT's Avatar
2wheels > 4 wheels
What year car ? I dont want to pull the pan that is a job on the 4.6 cars..The pan has to be pulled to use this.Also the 46 pan is not as deep as a 50 pan.Im not 100% sure this will work.
When you run the oil return line I was told not to drill the hole..How else do you reccomend I do it ?
