Vortec Oil return line
Old Jun 13, 2006 | 01:46 PM
Zman's Avatar
I gota Cheby
You use a punch, first a small punch and then you go to a bigger and bigger punch and then when the metal was folded in from punching the holes you then ran a tap. Thats how Vortech shows it for their supercharger install. Also grease up the tap to catch any metal shavings. Blue Oval will do the installs also. I just like that piece because i can tighten down snug which Vortech tells you to be careful and not over do it as you do not really have 360 degree thread
Only 1/4 mile track I know is Gandy Bridge
Old Jun 13, 2006 | 08:47 PM
xchief1320's Avatar
I have probably installed hundreds of SC's over the years for myself and customers and never had an issue with the punch/tap method.
Paxton sends a real nice punch with their kits that's short and ramps up fast so you don't have to worry about hitting the throw on the crank. After i tap it i just use RTV or JBWeld on the fitting so i know 100% it won't leak. I have never even came close to one wanting to strip on me. The tap is NPT so the further you go in the bigger the hole gets. i tap it about 3/4 way so the fitting starts easy the first few threads but tightens up pretty quick after that.
I have had ALOT of people bring their cars just for me to tap the pan. They are amazed when it takes 5 minutes to do the job. Alot of them think it's the hardest part of the install. Get a decently sized hammer otherwise you'll be there forever punching the hole.
Old Jun 13, 2006 | 11:35 PM
primetime1267's Avatar
Smacking Her A$$
I have used the method also, a whole helluva lot less work just to tap punch it...
Independent AMSOIL Dealer
XPSYNTHETICS.com
Sarasota, FL ZO#1863313
Old Jun 14, 2006 | 03:26 AM
o1yellowGT's Avatar
2wheels > 4 wheels
If you werent so far away I would bring it in also..
Old Jun 15, 2006 | 02:22 PM
Zman's Avatar
I gota Cheby
xchief1320 where are you located?
Old Jun 15, 2006 | 03:10 PM
  #17 (permalink)
Duceanahalf's Avatar
is doing your girlfriend
My Canton pan has a 1/8" NPT dip stick port. the turbo i have has a small 5/16" oil inlet, will the dip stick port be big enough for a drain? Im going to be running a -6 feed line and either a -6 or a -8 drain line.
Old Jun 15, 2006 | 06:49 PM
  #19 (permalink)
BigDawg's Avatar
has his prioritys ef'd up
At most you will ever need on a feed is -3, hell my billet flange is about the size of a ball point pen, coming from a -3, and yes the return needs to be ample enough, because when it comes out of that turbo, its like frappucino.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
