airbag?
Old Apr 5, 2006 | 06:23 PM
Drewpw4ng's Avatar
stock :-\
Default airbag?
when my car launched all the weight it put on the back right tire. Its an obvious lean to the right and the car wants to scoot to the left.. would an airbag fix this? if so where do i look for one
Old Apr 5, 2006 | 07:09 PM
steve's Avatar
madpom
what about a stronger spring rate for the rear right
Old Apr 5, 2006 | 07:11 PM
herrcomestrouble's Avatar
Moroso 'Trick springs' Or the Eibach Drag kit, will keep the car straight. Also check your air pressures...
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Old Apr 5, 2006 | 08:39 PM
bitemark46's Avatar
Got traction?
If you car is "scooting" to the left that means that the right rear is getting more traction then the left which is uncommon. So an airbag in the right rear is not going to help. Put one on the drivers side to get more downforce/load on that tire. That should straighten it out. -Mark
98' cobra
Old Apr 5, 2006 | 10:06 PM
topher469's Avatar
BillionClub Member BISHES
+1 on the Eibach drag springs, Work very good. As far as the "scooting" problem, I had the same issue under "heavy throttle application" lol, but it was a ripped upper control arm. Just something to check while you are under it. Good luck.
Old Apr 6, 2006 | 10:36 AM
Drewpw4ng's Avatar
stock :-\
hows the eibach kit on a daily driver. Is it like extremely loose around corners?? I have no front sway so im kinda used to it, but i just dont want something horrible to deal with.. Comfy springs or are they harsh over bumps n shit?
thanks
Old Apr 6, 2006 | 06:58 PM
Drewpw4ng's Avatar
stock :-\
anyone?
