Mach 1 BBK TB
Old Mar 15, 2006 | 04:53 PM
tbtstud17's Avatar
04 azure mach 1
Default Mach 1 BBK TB
does anyone know the difference between the models 1711 and 17110?
they are twin 65mm tb's but the 1711 says its for 99-02 cobras while the 17110 says its for the 03-04 cobra. which one will work on the mach? im guessing the 1711 bc the 17110 may be different for the blower. please give suggestions. thanks
Old Mar 16, 2006 | 05:12 AM
the anti-rice's Avatar
finally painted the car!
Not sure about the differences but Accufab also makes a oval T/B for modular cars.
-Ryan-
Old Mar 19, 2006 | 05:29 PM
tbtstud17's Avatar
04 azure mach 1
the accufab tb that is oval will cause problems on the car bc the 99-up dohc motors have a 2-hole intake manifold; however accufab does have a twin hole tb but it isnt as large as bbk's and wont flow as much air...anyways i called bbk who said the 1711 is for the mach 1 bc the 17110 has 2 springs for the throttle cable
Old Mar 20, 2006 | 03:35 AM
T/S #25's Avatar
Need To Get Quicker
Accufab is the way to go. It's a way nicer piece than the BBK. All you have to do is pull the upper and cut the 2 hole throttle body opening to match the oval opening needed for the Accufab.
Joe
FordSpeed Racing
9.78 @ 136.05
www.fordspeedracing.com
Old Mar 20, 2006 | 02:57 PM
Yeah. All 96+ 4Vs have that. Like you said, all you have to do is cut it out. Accufab > BBK
-Ryan-
