AC works only from de frosters
you been doin any under dash work??? You might have had a vacumn line come loose, the whole HVAC system is run on vacumn. Or you might have did some work under the hood, and knocked a vacumn hose under there loose.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Ryan
Originally Posted by Mr Goats
my main ac vents arrnt working but my defrosters are. what would the cause of this be? i drive a 96 mustang
yes check all the lines, very common problem. on 87-93 they have a vacuum ball located under the fender on the pass side that goes bad. Looks like a big plastic softball. Not sure where its on a 96
Only 1/4 mile track I know is Gandy Bridge
problem
its 100% a vacuum line problem...source vacuum to the head unit to be exact...start by checking the vacuum line that comes out of the cab into the engine compartment by the evaporator..trace it to the distribution block on the drivers fender well...if all is good there then you have a problem under the dash ...when the head unit doesnt have a source vacuum it goes into default mode and blows out the vents...
chad
chad
www.racinginnovationsfl.com
www.xsrcylinderheads.com
4.842@156 and 7.53@192 on radials
I have Had this problem!There Is a little line that Run's the back of the firewall!! I would check that one!! It Gose from the tree On the drive side!!! I Have broke that line twice when working on the car!!
chad
chad
