Too much HP?
Old Feb 13, 2006 | 12:29 PM
BigDawg's Avatar
has his prioritys ef'd up
There are plenty of stock block cars pushing way over 500 horsepower, its all in the tune as Steve said, keep a safe A/F ratio and keep it dialed in, get a a standalone to further watch whats going on with everything. And dont O ring your heads, go with some cometics for your bore, and some ARP headstuds, you can easily push 600 on a stock block, I can think of at least 8 guys I knwo who are doing this.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Old Feb 13, 2006 | 12:33 PM
bottlefedLX's Avatar
Don't be so angry
Originally Posted by OldMan
First, go with 42lbs and no FMU!
I have a 6 psi kit w/42# injectors.....definiety ditch the FMU.
John
John
1992 Mustang LX 5.0-Powerdyne BD-11A, 3.73's, FRPP clutch, chrome Ponies, Mac headers, Aeromotive regulator, MSD 6A, MSD BTM, FRPP 42# injectors, Pro-Flow Air Optimizer, Trick Flow Track Heat intake, Edelbrock 75MM TB, AFM Power Pipe
Old Feb 13, 2006 | 03:01 PM
GB's Avatar
GB
Great Cornholio
Out of curiosity, why do away with the FMU?
SLEEPER
Old Feb 13, 2006 | 03:13 PM
DrDirt's Avatar
Team Geritol Racing
That's pretty close to the setup my last car had. It made 444.4 hp on my highest "safe" tune but I dialed it back to 417 hp. At that tune, it ran 11.07 at 126 and change in the 1/4. My best advice would be to dump the FMU and the 38's and get some 42# injectors, 50# if you would like a little headroom. Get a good dyno tune and a chip and you should be golden.
YO! Barry! You LOST!
Old Feb 13, 2006 | 03:20 PM
GB's Avatar
GB
Great Cornholio
Did you have any problem with the 42's dumping too much fuel when you were starting the car? The last setup I had the injectors were a little too big and to start the car sometimes you had to hold the pedal to the floor until it cranked, it was dumping too much fuel at times.
SLEEPER
Old Feb 13, 2006 | 04:47 PM
$hawn's Avatar
lives in a glass house
nah, 42#s with the proper MAF and tune it will purr like a kitten at idle...
for the record, I'm on the ditch the FMU bandwagon
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Feb 13, 2006 | 06:10 PM
  #17 (permalink)
FordGuy~347's Avatar
mach coming soon
go 10 psi....a guy i knew ran 14 (525rwhp) (he had a 93 cobra, with AFR 165's custom grind cam, 14 psi procharger, ect) and one tank of bad gas killed psiton #8 but of course those cobras did have hyperuetectic pistons.....still, i would rather be on the safe side....my dad has an 03 cobra with about 475rwhp and its way to much for the street to handle....you dont need the extra power, stay safe. 400rwhp will be plenty of fun, and you wont end up in a ditch if you let it all out at one time (almost got put in one this weekend.....when that boost comes on, its game on...about 100HP hits the ground at one time and if you got the pedal burried your tires will definatley break traction) first gear in the cobra is sweet but second is insane....as soon as that boost kicks in it becomes a different car....usually end up taking up 2 lanes .
good luck with your build, keep us updated
Old Feb 14, 2006 | 05:12 AM
  #19 (permalink)
Don't be so angry
There is a lag when using a FMU between vac and boost. If you are cruising in first and romp the throttle, there is a delay, then you get boost. I didn't care too much for it, so I went with 42#'s and ditched the FMU. I sometimes have hard starting problems like you described, but it is only when the car is runing, then I shut it off and try to start it again. But, while the car is running the power is smooth, not spikey.
John
John
John
Old Feb 14, 2006 | 11:28 AM
  #20 (permalink)
evocrazy1's Avatar
I'd do the run 42# inj and a decent sized maf, and get a great tune, its all in the tune
ASKED TO BE BANNED
