how was everyones night at the TRack?....pics
Old Dec 12, 2005 | 04:33 PM
  #51 (permalink)
SoL_93GT's Avatar
Originally Posted by shinysideup
Turbo is choked at that rpm
The power doens't drop off, I'm just not reving it higher due to where the tq comes in. That turbo should make power above 6000 rpm with the right setup, whats limiting me is the heads, intake, cam, ect. Max tq is coming in at 4200.
Briane
Red 93 GT with only 9000 original miles on it.
HP Performance Stage 1 Street kit with 60mm turbo
Car Pics
11.29 @ 126 mph 16 psi
16 lbs of boost 509 rwhp/626 rwtq
12 lbs of boost 433 rwhp/571 rwtq
********STOCK MOTOR*******
Old Dec 12, 2005 | 04:43 PM
  #52 (permalink)
LaserCobra's Avatar
I need a helmet.
Glad I didn't go because I bet my half-shafts would have let go if the track was that sticky early on... granted I'm still running street tires but with my luck...
Would have liked to see some of you run. So far all I've been able to do is read about it.
I really want to go to the next one but I need stickier tires and a helmet.
SOLD 6-17-06
'01 Silver Cobra #2709
Procharger P1SC w/10# pulley, 3 core IC, Bassani OR X, Steeda catback, 42# injectors, Lightning 80mm MAF, Tri-Ax, Fat Knob, Battery in da' trunk, JMS Tune 432rwhp / 390rwtq 12.54 @ 115 on street radials
SOLD 6-13-03
'98 Laser Red Cobra #634 of 5174
UPR Power Pipe, BBK off-road H, Flowmasters, 4.10 gears, battery relocated to da' trunk, rear seat delete, Cobra R 17x9 rims with Nitto 315's out back, shaved door locks, 13.35 @105
Old Dec 12, 2005 | 05:40 PM
  #53 (permalink)
Steve B's Avatar
brings his heater.
Originally Posted by SoL_93GT
I was wrong, I looked at the dyno sheet again and it makes max tq at 4200 and was under the impression you should shift at 15% higher than max tq. It does make 500 rwhp at 5550 but I also wanted to keep the rpm down to save the block. Do you think I should raise my shift points? Also as I'm sure you know the valves and ports are tiny and the stock cam makes more power down low. But you know more about this than me. Let me know what you think.
Briane
personally i would rev it to 6249, if it was mine of coure.
Old Dec 12, 2005 | 05:47 PM
  #54 (permalink)
Scarface's Avatar
change cars like socks
i launch my car about 6500-7000rpms dead hooks and take off
Old Dec 12, 2005 | 05:50 PM
  #55 (permalink)
T/S #25's Avatar
Need To Get Quicker
You should shift 300-400rpm past your peak horsepower RPM. If you made 500hp at 5550rpm, then you should be shifting around 5850-5950rpm.
What kind of horsepower numbers did you see at 6000?
Joe
FordSpeed Racing
9.78 @ 136.05
www.fordspeedracing.com
Old Dec 12, 2005 | 06:08 PM
  #56 (permalink)
SoL_93GT's Avatar
My bad, I thought it was max tq you look at when determining shift points. Max hp comes in at 4350, tq at 4200. I only mentioned that it made was still making 500 at 5500 to show that the power wasn't dropping off that much but I wasn't reving it that high due to the peak points being so low. Sorry if I confused you. I had Sammy shut if off at 5500 cause I didn't want any block splitting going on that day.
Briane
Car Pics
Old Dec 12, 2005 | 06:13 PM
  #57 (permalink)
T/S #25's Avatar
Need To Get Quicker
I understand.......but if my engine was making 500 rwhp at 5000rpm.......I would be shifting it higher if I was you.
Hell.......my engine doesn't make 500rwhp at 5000rpm.......it doesn't even make 500rwhp at any RPM.
Joe
FordSpeed Racing
9.78 @ 136.05
Old Dec 12, 2005 | 06:22 PM
  #58 (permalink)
SoL_93GT's Avatar
Cool, I'll try raising my shift points and see if it helps. And yeah I know I'm not using nearly all the power I'm making, if I was it would be going mid 10's at this weight, I've got alot of issues to work out. You're car must be dialed in to the hilt and light too. Gotta admit though making over 500 rwhp with 1.78, 1.46 valves and 160 cfm intake heads is pretty good. I just wish my car was setup to maximize the power it's putting out.
Briane
Car Pics
Old Dec 12, 2005 | 06:37 PM
  #59 (permalink)
T/S #25's Avatar
Need To Get Quicker
I'm not sure how light my car is. I am actually going to be putting it on the scales in the next day or two and see exactly what it is.
I know what it was when I had the 306/aluminum head/AOD combination. It will be interesting to see what the difference is with the 358/iron head/C-4.
Joe
FordSpeed Racing
9.78 @ 136.05
Old Dec 12, 2005 | 07:13 PM
  #60 (permalink)
Drewpw4ng's Avatar
stock :-\
where u gonna weight it at
