T5 Problems
I attemp to drive my car today for the first time after the t5 conversion. I put it in first and let out the clutch, it pops out of gear while grinding badly.
Cant use first at all, I was thinking it might be the syncros but not sure. Figured one of u on here would have had this problem and might be able to tell me what it is.
I say you find whoever sold you that tranny and beat them with the input shaft.
Originally Posted by TheShow50h
Maybe the shift stops are adusted too far foward and it's not totally going in gear?? If not, then it sounds like your tranny is fubar.
check the stops if not sounds lke syncros
Originally Posted by Cossack
did you have a tranny shop check it out before you bought or installed it.
Originally Posted by Mars_302
bent forks, bad blocker rings
You got ripped off.
Briane
Red 93 GT with only 9000 original miles on it.
HP Performance Stage 1 Street kit with 60mm turbo
Car Pics
11.29 @ 126 mph 16 psi
16 lbs of boost 509 rwhp/626 rwtq
12 lbs of boost 433 rwhp/571 rwtq
********STOCK MOTOR*******
Car Pics
