problems with 88 5.0 need help
Old Nov 30, 2005 | 02:50 PM
geoff's Avatar
2fast4u
Default problems with 88 5.0 need help
well here it goes. the starter went bad on it i believe. yesterday the car wouldnt start but just try and crank. we had jumpers up to the battery too. well eventually we said fuck it and i turned the ignition off and took out the key. to my surprise tho the car kept trying to crank itself. it did this for a couple seconds and then it started to smoke were the starter is. we disconected the battery so it wouldnt try that again. there was a very nasty burning smell. well today i put the stang on a jack and replaced the starter and the starter solenoid. the car didnt crank at all. the head lights didnt even come on. we tried to jump it and nothing. my friend then tried to jump it by the starter solenoid and there was spark and the motor tried to crank but nothing. i tried to start it with the key and nothing at all. not even an attempt to crank. so basically the car tries to start when you jump it through the starter solenoid but nothing when you try with the key. so anybody have these problems b4 or have any thoughts on what it might be. im new to the domestic scene and dont know too much.
Old Nov 30, 2005 | 03:07 PM
ODB's Avatar
ODB
S.Y.L.O.
just sell it to me....
did you make sure the small push on wire is on the solenoid??
Old Nov 30, 2005 | 03:47 PM
10sec89's Avatar
check all fusable links, does the fuel pump kick on when you try and start it?
88 LX Hatch,302, E-303, stock long block & Intakes
175 shot,60' 1.42 11.34@116
89 LX coupe, 306, 432 rwhp & 400rwtq 11.004@126. Before blower on all Nitrous 1.48 60' 10.79@122
05 Premium GT, 5 speed, spoiler delete, I.U.P., Dark charcoal leather interior. Stone stock 14.1@101, DeMolet C.A.I. & SCT Xcal2 87 octane tune 13.70@103 w/ 4.10 gears 13.35@105
2003 SVT Cobra. Usual bolt on's 11.61@122
http:/momsracing.com/
Old Nov 30, 2005 | 06:35 PM
nasdstang's Avatar
need turbo stuff,pm me
ignition switch prolly took a crap or your solenoid fried itself
-Ronald Reagan
Old Nov 30, 2005 | 09:49 PM
evocrazy1's Avatar
i had the same problem, one of the fusible links is bad, or the car has a bad ground, check to see if the neg battery cable is loose at the block behind the ac bracket. if its clean and tight, make sure you have the short ground going from the negative on the battery to the chassis behind the battery up on the fenderwell. if it still doesnt work you have a bad fusible link
ASKED TO BE BANNED
Old Dec 1, 2005 | 07:47 AM
geoff's Avatar
2fast4u
its definatley not the solenoid. i just got it. so even with a bad connection why would it not start from the inside but only try to start when i try and jump it through the solenoid. and yes the fuel pump turns on
Old Dec 1, 2005 | 07:49 AM
Steve B's Avatar
brings his heater.
you forgot to hook a wire up, there should be two small studs sticking out on the solenoid. there also is a red wire with a right angle rubber boot thingy on it. it goes on one of the studs.
Old Dec 1, 2005 | 11:01 AM
evocrazy1's Avatar
yeah it does, sounds like a burnt up ignition switch. not the lock cylinder.
ASKED TO BE BANNED
Old Dec 1, 2005 | 02:26 PM
geoff's Avatar
2fast4u
ignition switch? where is that located and anybody know how much that is going to run me?
