problems with 88 5.0 need help
Old Dec 1, 2005 | 06:52 PM
randrade1's Avatar
2004 Cobra
try using another battery? had something a long time happen that was similar. the battery was so far gone that jumping it was giving it enough juice.
a fusable link too.
Old Dec 6, 2005 | 06:16 PM
fordracing373's Avatar
Hey dude igniton swith is on the bottom left side of the steering column the wire from the starter solenoid runs through the igniton switch and to the wire from the lock cylinder. As far as the motor still trying to crank it burnt the switch closed then shorted out. Try the igniton switch is the best place to start. if u need anymore help pm me.
Old Dec 6, 2005 | 07:16 PM
Na306StAnG's Avatar
Flowmaster nut swinger
since the headlights are also not working I would say it would have to be a fusible link
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Dec 6, 2005 | 07:51 PM
JDL1000's Avatar
Originally Posted by nasdstang
ignition switch prolly took a crap
It sounds like the ignition switch like Mike said.
Ford had a recall on them for burning up inside. The switch is only about 15.00 at any Ford dealer and they usually have them instock.
Life moves pretty fast. If you don't stop and look around once in awhile, you could miss it.
-- Ferris Bueller --
