looking for some help....
Old Nov 25, 2005 | 06:41 PM
Corner Worker's Avatar
Default looking for some help....
I have a 302 (86block) with track heat intake, twisted wedge heads, stage 1 trick flow cam, and long tubes. I am running the Holley Commander 950 DFI, and I can not get the car to idle well at all. It surges so bad it wants to stall. I adjust the idle air control, and it idles great, at 1500...I wanna be around 950-1000. I am starting to think its either the cam, or the computer. I talked to the holley tech, and he suggested a few things, didnt make a difference. I know a couple people that have used the trick flow cam, and had very similar results...any help on the subject would be much appreciated.....
the cause of all that is evil
Old Nov 25, 2005 | 06:54 PM
nasdstang's Avatar
need turbo stuff,pm me
bump your timing down and it will lower the idle also.
or adjust your throttle position sensor
just a thought.
-Ronald Reagan
Old Nov 25, 2005 | 07:41 PM
Steve B's Avatar
brings his heater.
have you tried a stock computer?
nice project btw.
Old Nov 25, 2005 | 07:57 PM
shinysideup's Avatar
TR Balla Donor Supreme
sounds like a simpler problem.
vacuum leak= surges bad. check all the openings and hoses. If you have access to a simple vacuum guage hook it up and see what its holding.
Old Nov 25, 2005 | 10:24 PM
the TPS has nothing to do with the way it idles. The commander computer recognizes where its at in relation to the high setting to calibrate the voltage, so that's not it...I dont have a stock computer/ stock wiring harness to try, but I was thinking that route. I have a DFI, I should be able to make it work, dammit lol. A vacuum leak will give the same crazy idle....I will see what I can come up with. I just have heard nothing good about those trick flow cams, and thought it might be the problem.
Old Nov 26, 2005 | 03:32 AM
nasdstang's Avatar
tps Will make it surge. i just threw out a few to get you started
my advice in this thread is DONE
-Ronald Reagan
Old Nov 26, 2005 | 03:37 AM
DrDirt's Avatar
Team Geritol Racing
I had a trick flow stage 1 in my last car with a Vortech S-trim. Worked great with no idle problems. Had a JMS chip in it. Current car with turbo is idling at about 900 with a trick flow stage 2 cam. How about you idle air control? Is it stuck or dirty? Also, just for grins, you might check your firing order to make sure yo didn't accidentally cross some wires. Plus there are two firing orders on 302's depending on which engine you have. Another possibility is a crack in the distributor cap or internal arcing check it out and look for little burnt trails.
YO! Barry! You LOST!
Old Nov 26, 2005 | 05:23 AM
JDL1000's Avatar
Sounds like your IAC solenoid is possibly bad or full of carbon. Take it off and clean it with carb cleaner. Sometimes you can save it by cleaning it instead of replacing it.
Hopefully you can make it to track day I'd like to see the car...
Life moves pretty fast. If you don't stop and look around once in awhile, you could miss it.
-- Ferris Bueller --
Old Nov 26, 2005 | 03:06 PM
evocrazy1's Avatar
i had the same issues with our 73 F-100 with a 393, with the pretty much the same setup. we ended up plumbing a factory harness and ecu, and then had it chip and run excellent, i dont think that the ecu for the holley cmmander is very well designed.
ASKED TO BE BANNED
Old Nov 26, 2005 | 03:14 PM
Scarface's Avatar
change cars like socks
i think its the IAC common problem on mustangs.....by the why very nice car i alway liked v8 rx7's specialy ford powered ...nice work
