Ford starters sensitive to resistance?
Old Nov 21, 2005 | 10:50 AM
F*r*a*n*k*e*i's Avatar
Default Ford starters sensitive to resistance?
There's a big note on Advance Auto Parts' website that says that the starter for the Torino is sensitive to resistance. The starter in the car currently won't turn over at all. I can hear the relay click, I get continuity through the relay, but no love. I pulled the wire from the relay to the starter, and it's got 6000 ohms of resistance on it, so, it's obviously rotten. I tried testing the starter by clipping a lead from my jumper cables to the starter and then tapping it to the battery, but no love still. Am I missing something in the circuit, the jumper cables put too much resistance still, or is the starter plainly dead?
Old Nov 21, 2005 | 11:33 AM
nasdstang's Avatar
need turbo stuff,pm me
is there a spayed terminal above the starter? if so run a jumper wire from the terminal where the cable is connected to the spayed terminal and it will complete the circuit
-Ronald Reagan
Old Nov 21, 2005 | 11:49 AM
I didn't see anything but one ring terminal on top of the starter with a big 4ga wire from the starter relay on the fender.
Originally Posted by Just Dave
If the battery is good, then it sounds as if the starter is dead. If you ran a jumper cable from the battery to the post on the starter then the starter should engage.
Typically, the solenoid is between the battery and starter. There's a small wire coming from the key switch. When the key is turned, that wire gets hot, closes the contacts on the solenoid, and completes the circuit between battery and starter.
Its pretty simple and you bypassed that so it sounds like weak battery or dead starter.
The battery was only at 8.5 volts, but I had a jumper set run from my Caddy with 2 12v batteries fully charged. I could hear the relay click when I turned the key, and like I said, I checked both sides while the key was engaged for continuity and it was there. I think the relay is fine. The previous owner said the starter used to act up, so it's probably just time for a starter. I even tried whacking it with a hammer a few times just in case it was siezed up.
There any tricks to installing a Ford starter on a 351C? I'm used to Chevy starters. Two bolts, two wires, done.
Old Nov 21, 2005 | 11:51 AM
Flastangs's Avatar
Should be two bolts and one big wire..if I remember correctly.
Old Nov 21, 2005 | 11:58 AM
Yup, the o-ring terminal was sandwiched between the two nuts. The wrench I had on the bottom nut slipped when I was trying to loosen the top one, so I might've broken the contacts inside the starter. Whatever, I'll just go buy a new one and throw it in this weekend.
Old Nov 21, 2005 | 03:31 PM
SmokinS13SR20's Avatar
That ginger...
aww dangit man i wanted to see it up at wendys on friday why dont you run up to advance auto parts and get one my bro is working a 9-5 tomorrow at the one right by alderman you oughta bring the 67 up there so he can drool over it lol his name is randy and he has red hair lol just a thought enough of my rambling lol haha cya good luck with the car
-Joe
Old Nov 21, 2005 | 08:21 PM
-Joe
Heh, maybe the Friday after. I still have to clean out the car, it stinks, and get an exhaust manifold or a set of headers. If I run it like it is now, it'll surely catch on fire, and if it don't, I'll at least suffocate.
Is Randy skinny? I think he already drooled all over my '67 once
Old Nov 21, 2005 | 09:06 PM
That ginger...
yea hes kinda tall and ehh medium build i guess lol i dont blame him i would too lol
Old Nov 22, 2005 | 06:06 AM
That might've been him. I'll bring the Torino and the SS up to Wendy's one night so you can eyeball 'em both. Maybe I'll even get my roommate to drive my Caddy up.
