lifters tick
Old Nov 7, 2005 | 05:13 PM
91GTmike's Avatar
Talking lifters tick
has anyone ever have problems with there hydraulic roller lifters making a loud ticking noise, i was told that the lifter orifice was to be facing upward but thoght it was to be lined up with the oil gallery.
Old Nov 7, 2005 | 05:29 PM
Stewart Scott's Avatar
"Now I only have two"
I have the same issue with my lifters/rockers making noise at high rpm's. I think my issue is with a "weaker" lifter or my pushrod length needs to be checked. I am learning as I go and can let you know what I found out. Do you know if yours is correct? what cam, rocker, push rod are you using? I am running an F cam, stock ford lifters, 1.6 FMS rockers with a stock push rod length. LMK
God bless America!
God bless our troops!
God bless the GOP!
Old Nov 7, 2005 | 06:38 PM
91GTmike's Avatar
the whole valvetrain is stock, but i was reading in MM&FF december issue on there 347 stroker buildup and thought this might be the problem, it's not the rockers i checked those, and the motor was just rebuilt and has about 6,800 miles.
Steve B's Avatar
brings his heater.
are you sure it isn't the bottom end?
Old Nov 7, 2005 | 07:16 PM
91GTmike's Avatar
it does'nt have a that real deep metalic sound to it, im pretty sure it's a the lifters,the noise is about half the speed of the engine.
Old Nov 8, 2005 | 10:29 AM
Drewpw4ng's Avatar
stock :-\
mine does it too but only at idle to about 2k metal ticking.. 126k leaning toward a rebuild
Old Nov 8, 2005 | 11:37 AM
86stang's Avatar
I had a problem like that
Except it went away when the car had been running for about 7-8 minutes. Still, pretty annoying
Old Nov 8, 2005 | 12:02 PM
Lumberjack's Avatar
is made outa laffy taffy
how old are the lifters? could be stuck and not pumping up.
could be a loose rocker too ( exhaust ect. ) , but you should notice that easily.
All-American Street Car Performance
6187 126th ave north
Largo Fl 33773
727-667-9346
www.aastreetcars.com
