Not again WTF this is getting annoying and depressing
Old Nov 6, 2005 | 06:20 AM
Na306StAnG's Avatar
Flowmaster nut swinger
Default Not again WTF this is getting annoying and depressing
OK this is the third time this motor has had problems so I went out and spent the money to have my machine shop build it. I gave him a virgin 5.0 yyy block and my crank rods and pistons. He charged me 600 bucks to do everything clearance block for 347 assembly, line hone for D.S.S. Girdle, bore block to fit pistons, cam bearings, core plugs, including bearings and pistons rings. So i got the short block back about 2 weeks ago and this is what it looked like.
And this is what it looked like after i put the long block together
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Nov 6, 2005 | 06:28 AM
Na306StAnG's Avatar
OK so a week goes by the car is running great tranny is working perfect I had a couple problems with the starter but Joe from ford speed hooked me up. Tuesday night Wednesday I relashed the valves checked all the plugs changed the oil and jetted the carb 71 - 78 with a 4.5 power valve and 31 - 31 squirters. I took it to the track and first pass was a 7.462 but with a 1.8 60 foot the car should do 1.5's or even 1.4 with the suspension i have done. made 2 more passes 1 a 8.0 and 1 an 8.3 last pass car started to miss car never got above 185 i found some water in the oil so i pulled the heads and found this
Largo fl 33773
MV#72427
Old Nov 6, 2005 | 06:32 AM
Na306StAnG's Avatar
I talked to a bunch of people about this everyone seams to think the rings were not gapped right and they butted together but even if so there Je/SRP pistons but I guess anything is possible. I'm supposed to take it to the machine shop in the morning to have them take it apart. there are 2 broken pistons and 6 have hair line cracks
Largo fl 33773
MV#72427
Old Nov 6, 2005 | 06:36 AM
Na306StAnG's Avatar
Oh and no the motor was not shot with nitrous. This motor was built to take a 200 shot but i did not have it hooked up yet i still need a bottle and brakets
Largo fl 33773
MV#72427
Old Nov 6, 2005 | 08:57 AM
Scarface's Avatar
change cars like socks
damn thats sucks......glad u didnt spray it u might broke more parts than that..
Old Nov 6, 2005 | 11:19 AM
Stewart Scott's Avatar
"Now I only have two"
looks like your top ring land is broken on that one cylinder. That is from the rings not being gapped right or put in upside down or something. the heat at the top of the piston will expand the top side more and if the gap isn't correct it will crack that top groove. I think....that sucks bad...
God bless America!
God bless our troops!
God bless the GOP!
Old Nov 6, 2005 | 11:48 AM
Na306StAnG's Avatar
So should the machine shop replace my motor? I mean come on 2 pistons are broken and 6 out of 8 have hair line cracks in them i'm not using any of them and i want 8 new pistons and them to rebuild the motor again or is this asking to much the motor had 232 miles on it when i went to the track. i understand a race engine does not really have a warrenty but come on this is builder error not my fault.
Largo fl 33773
MV#72427
Old Nov 6, 2005 | 12:24 PM
I had a problem with some cam bearings that were installed and went back to the machine shop and made them correct it. If they built it and speced it then yeah I would go back to them and make them correct it. I don't know if you will be able to get what you want but it is definately worth the rant...and then find another shop!
God bless America!
God bless the GOP!
Old Nov 6, 2005 | 12:43 PM
nasdstang's Avatar
need turbo stuff,pm me
did you tell them it was gonna be raced at the dragstrip? if you did, you might as well hang it up. no one will gaurantee a raced motor. but if the shop is big on cust. sat. then they may fix it
-Ronald Reagan
Old Nov 6, 2005 | 04:11 PM
Na306StAnG's Avatar
I have lived here in clearwater for 5 years and have been using them for all 5 years. I told them that it would be raced but also that i was going to spray it with a 150- 200 shot and its does this N/A WTF i can't imagine what you have happend if A&E filled my bottle on time
Largo fl 33773
MV#72427
