Why does T-stat leak?
Old Sep 29, 2005 | 10:57 AM
Flastangs's Avatar
Question Why does T-stat leak?
When I dont run a T-stat the housing doesnt leak but when I put a thermostat in there it does....any ideas??
Old Sep 29, 2005 | 11:14 AM
ODB's Avatar
ODB
S.Y.L.O.
gasket and RV sealant useage?
Old Sep 29, 2005 | 11:53 AM
Flastangs's Avatar
yes on both...used gasket and RTV. If i take out the themostat and use new gasket and RTV it doesnt leak.
Old Sep 29, 2005 | 12:01 PM
Steve B's Avatar
brings his heater.
the thermostat housing has and identation for the t-stat to sit inside. if your not careful it will slip out and pinch between the intake and the water neck.
Old Sep 29, 2005 | 12:07 PM
$hawn's Avatar
lives in a glass house
I'd bet money that is the problem.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Sep 29, 2005 | 01:00 PM
Duceanahalf's Avatar
is doing your girlfriend
Originally Posted by Fordified
The position of the T-stat housing doesn't help much trying to get it to seat properly.
Ford Engineer #1 "Hey, you know, changing the thermostat on a Chevy is WAY too easy, lets put ours standing up instead of laying flat"
Ford Engineer #2 "yeah, that would work, but WAIT! Lets also put it BEHIND the timing cover, and so close that you can't use studs, that way, it will take FOREVER to change!"
only on a 302. on the 351 it is much easier to get at.
it is better than chevys engineering masterpiece of having the distributor at the wrong end of the motor so that it is hidden behind everything.
Old Sep 29, 2005 | 01:35 PM
freakyfast95GTS's Avatar
Ghillied up and ready.
I rtv it to the housing first then when its pretty dry I rtv the other side and bolt it down...never had one leak
" When you men get home and face an anti-war protester, look him in the eye and shake his hand.
Then, wink at his girlfriend because she knows she's dating a pussy." General Tommy Franks
"Congressmen who willfuly take actions during wartime that damage morale and undermine the military are saboteurs and should be arrested, exiled or hanged".
President Abraham Lincoln
Stewart Scott's Avatar
"Now I only have two"
+1 on indentation.
I used rtv on the inlet and placed the thermo in there and then after a few minutes put it on the car with the gasket. no leaks as of yet-probably will now though....
God bless America!
God bless our troops!
God bless the GOP!
