Valvecovers
Old Aug 16, 2005 | 06:55 AM
freakyfast95GTS's Avatar
Ghillied up and ready.
Default Valvecovers
am having a problem with valvecovers on my 95, need a cover that fits over roller rockers and will clear the elbow and not have the damn fill tube under the Throttlebody.thinking of taking 2 foxbody blank side and drilling them for breathers but can I keep or make the baffle work or should I go to the expensive bbk'S OR trick flows?
" When you men get home and face an anti-war protester, look him in the eye and shake his hand.
Then, wink at his girlfriend because she knows she's dating a pussy." General Tommy Franks
"Congressmen who willfuly take actions during wartime that damage morale and undermine the military are saboteurs and should be arrested, exiled or hanged".
President Abraham Lincoln
Old Aug 16, 2005 | 10:40 AM
69Boss521's Avatar
PORK CHOP SAMICHES!!!!!
Trick Flow Valve Covers..... you can tap them and put the fill cap wherever you want. Use a 1-1/8 hole cutter you put on a drill. Trick flow even sells the oil filler cap to go into the valve cover.
Blank Valve Covers
On the driver side you can see the oil filler cap, it has a vacum port on the side that I ran to the air cleaner. I put a normal breather cap on the other side.
In the end I put the filler cap on the pass side and ran an elbow to a tube to a breather tank to seperate oil dribble from the gasses. I am getting more blow by than normal on this high compression motor.
Derp!
Old Aug 16, 2005 | 11:20 AM
nasdstang's Avatar
need turbo stuff,pm me
hey jay, is that the rad from JRE?
-Ronald Reagan
Old Aug 16, 2005 | 01:34 PM
69Boss521's Avatar
YEP! Works damn good too!
Derp!
Old Aug 16, 2005 | 01:39 PM
Duceanahalf's Avatar
is doing your girlfriend
will those Trick flow valve covers clear an FEI motor? they look as tall as my cast aluminum summit V.C. on my carbed windsor
Old Aug 16, 2005 | 06:47 PM
evocrazy1's Avatar
i do know that with roller rockers you cant use baffles, i tried and bent a pushrod
ASKED TO BE BANNED
Old Aug 16, 2005 | 06:59 PM
dnstommy's Avatar
Call me Chris :)
Ford Motorsports puts the oil fill on driver front.
Old Aug 17, 2005 | 04:30 PM
Scarface's Avatar
change cars like socks
i used the foxbody valve covers on my sn95....they clear perfect my 1.72 roller rockers and i didnt need a intake spacer
Old Aug 17, 2005 | 07:16 PM
what did you do to keep oil from shooting out of the breather hole?
Old Aug 18, 2005 | 11:19 AM
evocrazy1's Avatar
you cap it off or you can put a small breather element
ASKED TO BE BANNED
