need help with comp ratio
anyone know how to get your compression ratio? the formula, or a quick way? i was told that the comp ratiowas 13:1 w/ a .041 gasket, but my buddy said he thinks it will be higher. and i want to be certain. thanks in advance
-Ronald Reagan
-Ronald Reagan
Originally Posted by primetime1267
Use strawberry jam-- 1 berry per comp. ratio
Im a
Hey did you ever find out about the lifters??
Im a
-Ronald Reagan
-Ronald Reagan
A compression tester won't work.
The most accurate way to figure it out is to "pour" the engine. You will need a CC buret for this.
You need to have everything ready for your final assembly. Install the crank, one rod, one piston, with the top compression ring installed. Make sure to put some grease on the ring. Next, install your cylinder head with a head gasket and torque it down. Preferably with a gasket that has been compressed already. Then, tilt the engine over so the spark plug hole is facing up. Fill the cylinder through the spark plug hole with fluid, making sure to get all the air out.
When you get that number, let me know what it is, and I will be able to tell you what your compression ratio will be.
what is it cc's? can i still do it if its in the car? thanks joe
-Ronald Reagan
-Ronald Reagan
a compression "tester" will only tell you what each cylinder is pumping, and allow you to determine if you've got rings going, leaking valves, etc.
not sure what you're referring to as a "compression ratio tool". There isn't any device (that I know of) that would take into consideration all of the variables (cam lift, durration, etc) that would allow a plug and play type setup..
please explain..
please explain..
I am your penalty.....
please explain..
please explain..
i'm with you on this one, i'm pretty lost as to what he's even asking...
just tell us the combo and i'm sure someone can tell you what you want to know. you said something about head gasket thickness. are you going up or down? as that all your trying to find out?
