Re Wiring AC
Old Jul 18, 2005 | 06:01 PM
69Boss521's Avatar
PORK CHOP SAMICHES!!!!!
Default Re Wiring AC
Anyone ever rewire their ac compressor? When I pulled the EFI harness out the wires to the compressor went with it. Has anyone ever fooled around with this sort of thing? Can't I just run a switch to it to kick it on and off?
Derp!
Old Jul 18, 2005 | 06:39 PM
$hawn's Avatar
lives in a glass house
yea but run it through the pressure switch on top of the accumulator so it will cycle. tap in to get your power from behind the selector switch when it's hot in a/c-defrost.
you'll no longer have a WOT cut off so keep that in mind.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Jul 18, 2005 | 06:46 PM
$hawn's Avatar
Originally Posted by Fordified
You'll also need to run it through the low pressure switch as a safety in case the refrigerant gets low. Basically find the switched hot wire at the A/C controls, run it to the low pressure switch, from low pressure to high pressure, from high pressure to clutch, from clutch to ground. When power is applied and both pressure switches close contacts, the A/C clutch will engage.
Doesn't a fox only have a low pressure switch?
Old Jul 19, 2005 | 08:01 AM
$hawn's Avatar
hmmm, now you have me wondering. I thought it would need a high pressure switch to tell the compressor when to cycle and a low pressure switch to keep the compressor from burning up if there is a refrigerant leak (and to cycle the compressor I suppose) You would probably know more than me though.
The s/n 95s have a high and a low but the older cars only have the the low pressure switched.
Most of the time when you have to "re wire" one you can jump the hot wire in at the hot side of the low pressure switch and all is well. You wouldn't believe some of the shit I get here.
Old Jul 19, 2005 | 11:25 AM
69Boss521's Avatar
ok so wich is it? So run a line from the "HOT" switch the AC selector controls to the Low pressure module on top of the accumulator, then from that to the clutch, then run a ground wire to the other terminal on the clutch to complete the circuit?
Derp!
Old Jul 19, 2005 | 11:39 AM
$hawn's Avatar
yes. pick up the power from the a/c selector then out through the low pressure switch then to the compressor clutch and ground the other side of the clutch.
Old Jul 20, 2005 | 11:56 AM
69Boss521's Avatar
does it matter which side I run the hot wire too first on the pressure switch on the accumulator?
Derp!
