New Motor
Originally Posted by evocrazy1
Very true, but i dont plan on running it higher than 6000, since its a daily driver would it be better if i just kept the F-cam even tho it has more duration? or what other cam could i use to give me power from say 3500 to 6000? I just want suggestions
If you never plan on turning it more than 6 grand, why would you want a cam that is rate for more than that? Personally, I would suggest staying with an E-cam that makes the power between 2500 and 5500. It is friendly for juice and blower setups, plus it had a lumpy idle to give the girl something to complain about while your taking her to dinner. Also, you don't have to twist your motor to 6000 to get all of the E-cam. High compression + juice is already going to give you a quick whip. Do you want to squeeze every pony out of it or do you want to keep it on the street for a while?
I run the E-cam in my blower car and won't ever change it.... but that is what I would do.
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
SC Motorsports
11801 State Road 52
(727) 856-8768
FordSpeed Racing
Largo, FL 33773
(727) 549-8255
yeah it has to last 2 yrs, till i move to houston. i think thats what i do, F-cam is gone and i'll use a E-cam, with 1.7s, how much power you think this will make to the ground with and without nitrous, i have a manual, alum. driveshaft and such, also what do you think it will make on 100 octane, cuz its like 3.99 a gallon up here. i just want to know cuz there is a boosted hatch up here, and he runs 8.30's on slicks, with the same setup, i run 8.5-6 consistantly on slicks as she sits right now. and he was talkin trash, just wondering what you guys think it'll run with 3.73's, and the bottle, for 1/4 and 1/8 on 26 x 10.5 m/t et's
ASKED TO BE BANNED
ASKED TO BE BANNED
Guest
Posts: n/a
Whats your guys opinion on the F cam, i have the valve clearance to run up to .580 lift, and i have .600 lift springs on the heads. would it be worth it run a X-cam with 1.6s instead of the F-cam with 1.6s and 1.7s cuz i'm gonna have sometime before i can put in the cam, I bought a Milodon 7 qt pan, i think it'll be smart to put in a Hi-Volume pump. and where can i get a hardened oil pump drive?
Go with the F cam, I know it worked great n/a and with the boost for me. The X is pretty damn rough.
A good oil pump can be had here from what I understand
www.precisionoilpumps.com
They are blueprinted and have some very meaty internal.
Get the oil pump shaft from ARP. You will pay a little more for it but it will be well worth it because snapping it would result in a fubared motor. One thing to check though is the thread engagement of the pump shaft into the oil pump itself. We had to do some modifing to get it just right.
Best of luck with it, sounds like you are on the right path. Just don't cheap out on critical things like bearings, oiling, etc..
i dont going cheap on critical things, especially bearings and oiling, etc. Well the F-cam is whats in their now, so i'll use it, and if i dont like it, i get and E-cam or something from Fox lake or AFM. I really want the car to have lots of useable power on the street and at the track, but i also want it be somewhat mannerly on the street. I would be in the process of putting it all in the car but i dont have my pan, or my welded and ported explorer lower. So thats really what is holding me up. What kind of balancer should i use? I also have underdrive pullies that have a 35% underdrive, so it has to the same thickness as the stock harmonic balancer to a t.
ASKED TO BE BANNED
ASKED TO BE BANNED
and made 300 with a stock t/b and 87 octane. My car is WAY heavier and run consistant 8.1-2 N/A.
thats not bad shaun, i know your cars quick. Well i liked the 4.30's but with the bottle, it was flying through the gears. So i'm gonna put 3.73's so everyonce in a while i can go run the quarter down in charlotte. I'll stick with the F-cam for now. I'll build the car the way i want. No matter what she bitches about. If its a problem just take her car. Shaun, whats 4 cid
ASKED TO BE BANNED
ASKED TO BE BANNED
SC Motorsports
11801 State Road 52
(727) 856-8768
FordSpeed Racing
Largo, FL 33773
(727) 549-8255
SC Motorsports
11801 State Road 52
(727) 856-8768
FordSpeed Racing
Largo, FL 33773
(727) 549-8255
just wainting on the pan, and oil pump, thanks scott for the recommending the precision pumps, a coule of pple up here also recommend them, so i got 1 from a guy up here. the beasty little pumps, i cant wait to get her in a fire her up.
ASKED TO BE BANNED
ASKED TO BE BANNED
yeah i got the idea brett, i told her that last night, and she was like, thats fine, and i dont really like driving a manual in hills, so its all good, !HAIL! to the Scion
ASKED TO BE BANNED
ASKED TO BE BANNED
PS. I hate to say it, but I used to do what the woman wanted as well. However the car is still here after ten years and there have been several girls through that time. So this is just my bias side talking....
Good luck with things....
SC Motorsports
11801 State Road 52
(727) 856-8768
FordSpeed Racing
Largo, FL 33773
(727) 549-8255
SC Motorsports
11801 State Road 52
(727) 856-8768
FordSpeed Racing
Largo, FL 33773
(727) 549-8255
