Mustang 5.0 Question
Old Jul 3, 2005 | 02:09 AM
Brandon's Avatar
Resident Dingo
Default Mustang 5.0 Question
Driving my car around... everything is fine. Next thing i know, the car feels like it misses 2 or 3 times, then backfires really loud a couple of times. It died once when it did this. I'm thinking that it's not getting spark or something.. let me know what you guys think this might be, maybe you have more ideas of things to check.
BTW: I'm going to buy new plugs and wires for it this morning.
--brandon
Old Jul 3, 2005 | 02:20 AM
dohcvtec's Avatar
You boys like Mexico!!!
I think......................
u need the AWD Hawtn33s....j/p good luck fixing the ferd and were waiting on u to pick us up
Springhill
22" Nothing less
Old Jul 3, 2005 | 05:58 AM
blown1989stang's Avatar
try the distributor same thing happened to mine i would get moisture in it so i put a boot on it and it was fine ever since
Old Jul 3, 2005 | 06:00 AM
dohcvtec's Avatar
he just picked up rotar..plugs...wires and cap
Springhill
22" Nothing less
Old Jul 3, 2005 | 06:57 AM
Steve B's Avatar
brings his heater.
what kind of rocker arms do you have? are they loose? its a long shot if dave's suggestion doesnt pan out.
Old Jul 3, 2005 | 08:53 AM
Brandon's Avatar
Resident Dingo
Originally Posted by Fordified
you might want to replace the TFI module that bolts to the side of the distributor (where the big harness plug goes into). They are notorious for going bad (especially when they are hot, after you've been driving for a bit)
That's when it happened.. been driving for a while (coming up the parkway probably cruising at like 80); water temp was around 180 when the problem started.
When i get the cap rotor plugs and wires in, if the problem persists i'll chk this out because that explains when it happened. We shall see.. thanx for the input
--brandon
Old Jul 3, 2005 | 05:10 PM
Brandon's Avatar
Resident Dingo
UPDATE:
Well i changed the ignition coil, plugs, wires, dist. cap/rotor and everything seems to be well at this point. I'm just going to cross my fingers and hope that it's not anything else, or something more serious. Thanx again for everyone's input. If the problem persists i'm still going to chk up on that TFI Module because that sounds like it could potentially be the problem.
--brandon
EDIT: if you know the part# for the special tool to get off that module let me know. Thank you
Old Jul 3, 2005 | 10:52 PM
Brandon's Avatar
Resident Dingo
Okay, now the car runs fine but has a bad idle surge problem.. could this be due to the TFI... thanx
Old Jul 3, 2005 | 11:18 PM
evocrazy1's Avatar
no iy would be the iac motor on the throttle body
ASKED TO BE BANNED
